0-60 in slow
Drives: light blue liftback Join Date: Aug 2009
I'm a bit fortunate to have access to shop equipment but I've been cutting everything with a band saw, grinder, or belt sander.
So in order to get the clean cuts after I make the initial cut I deburr the edge of the tube both inside and out and it makes that nice clean lines, makes it way easier to weld as well apparently too. I can't take all the credit though, I'm getting lots of help from the welder on how to properly work with tubing. I'm amazing on how much work it is to make these pipes, its been quite fun, but quite a bit of work. I wish I took some more pictures after I got the collector on but it was getting late and I needed to home. Hopefully I'll get the other 2 pipes welded up tomorrow and a initial test fit to see if everything's kosher. Something I thought was a bit funny but my primaries right now on my tri-y header are longer than the primaries on the stock header and I still have about 2 feet of secondaries to add. |
#2 | |
play every day
Drives: 2012 Yaris L 2dr 5sp Join Date: Apr 2012
![]() (just joking )
0-60 in slow
I have dyno results from when I was stock, but I'm going to dyno it against a DC header after its been vetted.
LOL its going to be close but thats all I'm going to say ![]() Another taste ;)
play every day
Is your header going to have an 02 sensor bung? I was thinking of chopping my WR header in half and adding a couple of straight tubes to lengthen it.
#5 | |
![]() ![]() ![]() ![]() ![]() Drives: 2015 H Production Yaris Join Date: Oct 2009
2005-2008 SCCA Solo BS National Champion 2017-2018 SCCA H Prod National Champion
| OBX Header | Galavoxx | Performance Modifications | 3 | 04-20-2007 11:36 AM |
| Megan Header Advice | jamal1984 | Cosmetic Modifications (Exterior/Interior) | 1 | 02-20-2007 07:22 PM |
| Weapon-R Header (4-2-1) | CASTREX | Performance Modifications | 28 | 02-19-2007 01:57 PM |
| Motor oil debate - interesting info but a long read. | mikeukrainetz | General Yaris / Vitz Discussion | 6 | 12-10-2006 08:16 PM |
| New car shopping - long post | littlecarlove | General Yaris / Vitz Discussion | 19 | 11-01-2006 10:58 PM |
