Old 11-21-2012, 06:04 PM   #1
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
I only was thinking about lengthening the secondaries as its easier.
The logical place to cut would be at the first welded joint up from the bung where everything is pointing straight at each other.
Old 11-21-2012, 06:10 PM   #2
xnamerxx
0-60 in slow
xnamerxx's Avatar
Drives: light blue liftback
I don't think you'll see any benefits to doing so just because the primaries are far more important than the secondaries for base scavenging.
What I would do is cut the point before the primaries join get a u bend SS in the right diameter cut and bend it so the pipes sit on top of each other like a 4-1 and pull them out about 18-30"s and use the existing merges as a way to terminate the pipes.
Old 11-21-2012, 06:15 PM   #3
Jason@SportsCar
Cut the tubes off at the flange and start over, it would be less work. A lot of fab guys hate coming in and trying to piece stuff together from an existing part - they seem to look at it as fixing the previous guys screw up. In the end the labor to piece together cost more than building from scratch.
Old 11-21-2012, 06:46 PM   #4
tooter
play every day
tooter's Avatar
But I'm the fab guy.
Old 11-21-2012, 07:26 PM   #5
Jason@SportsCar
You are making it to easy. But hey, if you want to build another part with no appreciable gains for the hell of it.
The only way to know is to try, worst case you cut up a relatively inexpensive header and waste a few hours.
Old 11-21-2012, 07:54 PM   #6
tooter
play every day
tooter's Avatar
That's what life is all about... finding out.
Old 11-22-2012, 12:52 AM   #7
xnamerxx
0-60 in slow
xnamerxx's Avatar
Well last update for a bit...I won't be able to start up on this project until next week as well as I need to get a few flanged cut to mate the 2 sections of pipe to allow installation. Again I wish I would have chosen a 4-1 design soo much easier to work with. I say this because the header path has a kink to the left and a quite narrow path that it needs to fit in.
Old 11-22-2012, 11:24 AM   #8
tooter
play every day
tooter's Avatar
Wow...
Man, that's absolutely beautiful work.
Are you using a jig, or the car itself for test fitting?
Old 11-23-2012, 10:02 AM   #9
vten
[QUOTE
[/QUOTE]
wow me likey ...any chance you'd make an extra copy for me :P ?
this and a custom midpipe, 200 cells race cat, and custom central muffler with a dual twin outlet would be noiceee!!
awesome build sir
OBX Header Galavoxx Performance Modifications 3 04-20-2007 11:36 AM
Megan Header Advice jamal1984 Cosmetic Modifications (Exterior/Interior) 1 02-20-2007 07:22 PM
Weapon-R Header (4-2-1) CASTREX Performance Modifications 28 02-19-2007 01:57 PM
Motor oil debate - interesting info but a long read. mikeukrainetz General Yaris / Vitz Discussion 6 12-10-2006 08:16 PM
New car shopping - long post littlecarlove General Yaris / Vitz Discussion 19 11-01-2006 10:58 PM
