Go Back   Toyota Yaris Forums - Ultimate Yaris Enthusiast Site > Second Generation Toyota Yaris Main Rooms > Regional Forums > UK
Old 11-24-2012, 10:28 AM   #3
If it is not an real OEM one, then the position of the bottom tabs in probably off by just enough to not snap in. I had the same issue with an aftermarket set of ones with LED turn signals built in, and I ended up having to use the OEM backing and move the aftermarket glass over. In you case, that is obviously not an option.
Try pulling the spring clip, so you can try snapping the mirror onto the backing separate from the car. That was you can better see what the issue is, and trim or do whatever is necessary to then let it work when you remount the backing.
