Old 11-25-2012, 11:23 PM   #8
xnamerxx
0-60 in slow
xnamerxx's Avatar
Drives: light blue liftback
The stock motor doesn't have a flex joint, it uses a ball and socket joint. The reason the joint is located where it is stock is because that's the easiest and cheapest place to put it. There does have to be some flex in the exhaust and ideally it should be as close to the motor as possible but you work with the space you're given.
The exhaust itself is hung which allows some movement there so the only reason you even need flex in the exhaust itself is to reduce the wagging motion of the main pipe and reduce load from the header. If you look at the header there is a support beam the bolts to the block and the header and that's what's carrying most of the fore and aft load from the header which is another reason why the ball and socket is located where it is. I've done some analysis on this I have an idea of where the load is sitting. If the side bracket isn't in place all of the load will sit on the flange and the failure will be located on the flange, if the side bracket is in place the pipes are thick enough to handle most of the load but the secondary flange will still be taking some load under movement but its substantially less with the flex joint in place. So to get some flex I chose a flex joint over a ball and socket because its easier for me to incorporate it the multiple center section exhausts that I have.
OBX Header Galavoxx Performance Modifications 3 04-20-2007 11:36 AM
Megan Header Advice jamal1984 Cosmetic Modifications (Exterior/Interior) 1 02-20-2007 07:22 PM
Weapon-R Header (4-2-1) CASTREX Performance Modifications 28 02-19-2007 01:57 PM
Motor oil debate - interesting info but a long read. mikeukrainetz General Yaris / Vitz Discussion 6 12-10-2006 08:16 PM
New car shopping - long post littlecarlove General Yaris / Vitz Discussion 19 11-01-2006 10:58 PM
