Old 12-01-2012, 10:30 PM   #1
xnamerxx
0-60 in slow
xnamerxx's Avatar
Drives: light blue liftback
Originally Posted by malibuguy View Post
the motor mounts in our cars are incredibly soft & these motors go all over the place. a flex joint at the end of a 3-4foot long 'lever' would not be adequate.
to get an idea of how much front scratchers (FWDs) boucne about. go to your local test-n-tune with all the kids beating the fuck out their cars...its quite alarming.
the flex joint NEEDS to be located as close as possible to the motor to reduce the leverage on the rest of the exhaust, period. the further away it is, the less its able to absorb.
I've measured a touch over 2.5",on the rev limiter, of movement. With that being said it doesn't matter in my case since my roll mount will have been taken care of.
Yep, but you can't package a a flex joint in the location it needs to be in with joints that are a proper diameter.
Old 12-04-2012, 10:28 PM   #2
Viperoni
Drives: 2005 Toyota Echo
I've already got the 2-1 section of my header welded up, and it's mostly made up of a pair of 10" long, 1.75" ID flex pipes. Should allow for tons of flexibility, right where it's needed.
2006 Saturn Ion Redline
2005 Toyota Echo RS 4dr hatch - Cyl #3 bad - sold
2000 Toyota Echo 2dr coupe - The track car - rusty & scrapped
Viperoni is offline   Reply With Quote
Old 12-04-2012, 10:58 PM   #3
xnamerxx
0-60 in slow
xnamerxx's Avatar
I'm tired of arguing this point. There is lots of math and formulas to determine the best length and diameter for a header. The formula I use specifies something different than what you chose to use. With the dimensions I chose I cannot package a flex pipe on the secondaries and wouldn't do so because laminar flow is substantially worse through a flex pipe than a tube. If you look inside a flex pipe there is a series of baffles which make it behave similar to that of a crush bent tube.
Old 12-05-2012, 12:46 AM   #4
xnamerxx
0-60 in slow
xnamerxx's Avatar
I'm not using the stock dog bone spring bolts flex joints are all irrelevant. The only reason I'm even considering a flex joint is to reduce exhaust noise slightly and help remove thermal growth caused by the catalyst.
My comment about the flex joint is that the bellows cause friction in fluid flow which causes turbulence which reduces flow. For that alone I wouldn't want to run them in my primaries where any slowing of gas flow can have drastic consequences.
I've done the math, run the simulations and calculated the load and stress points. I'm very confident in my design that I don't feel its going to suffer a fatigue failure.
Old 12-05-2012, 09:29 AM   #5
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
Dude, you're so worked up you can't even read what I typed. I said SLIP JOINT. Not FLEX JOINT.
This is a Slip Joint.
Old 12-05-2012, 11:08 AM   #6
xnamerxx
0-60 in slow
xnamerxx's Avatar
I skipped over that point as I assumed you thought slip joints are a way to control exhaust flex.
Yes I did consider a slip joint originally as a way to join the 2 sections of pipe but chose against it for various reasons. The biggest reason I chose against it was that slip joints are weak. In my situation there is still load traveling through the second set of pipe even though there is minimal engine movement in the exhaust its still carrying the load from the 30 lbs of exhaust and that load is effectively being distributed through only one of the pipes which doesn't have a ton of bearing area. If I was mounting the second section of pipe lower down I would probably go to a slip joint, it wasn't appropriate in my situation.
Old 12-05-2012, 11:16 AM   #7
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
Would one of these help?
Old 12-05-2012, 11:38 AM   #8
xnamerxx
0-60 in slow
xnamerxx's Avatar
I don't know maybe. I prefer to stiffen the dogbone rather than add weight somewhere else.
Old 12-05-2012, 11:43 AM   #9
Jason@SportsCar
I think some of you guys are loosing focus on the big picture... Build a prototype, get it on the car and see if it makes power. If needed issues like a flex joint, ball joint or the engine support can be addressed when a production piece is made.
Old 12-27-2012, 04:12 PM   #10
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
my comment about the flex joint is that the bellows cause friction in fluid flow which causes turbulence which reduces flow. For that alone I wouldn't want to run them in my primaries where any slowing of gas flow can have drastic consequences.
that is true if your using a low quality flex-joint. Ones like the premium Vibrant units feature a very smooth liner that is not restrictive at all.
Im glad you got it all done & i cannot wait to see the results!
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
OBX Header Galavoxx Performance Modifications 3 04-20-2007 11:36 AM
Megan Header Advice jamal1984 Cosmetic Modifications (Exterior/Interior) 1 02-20-2007 07:22 PM
Weapon-R Header (4-2-1) CASTREX Performance Modifications 28 02-19-2007 01:57 PM
Motor oil debate - interesting info but a long read. mikeukrainetz General Yaris / Vitz Discussion 6 12-10-2006 08:16 PM
New car shopping - long post littlecarlove General Yaris / Vitz Discussion 19 11-01-2006 10:58 PM
