Old 12-02-2012, 01:20 AM   #9
xnamerxx
0-60 in slow
xnamerxx's Avatar
Drives: light blue liftback
Flux core welds look like crap but you should be able to weld SS with it as long as you have the correct filler.
There's also quite a bit more that needs to be considered with header design, just welding longer tubes can actually result in power loss if it calls into a dead range where the reverse shockwave happens too quickly or too slowly. There are other things to consider in regards to load and heat and such but that would quite a bit of time to type out.
OBX Header Galavoxx Performance Modifications 3 04-20-2007 11:36 AM
Megan Header Advice jamal1984 Cosmetic Modifications (Exterior/Interior) 1 02-20-2007 07:22 PM
Weapon-R Header (4-2-1) CASTREX Performance Modifications 28 02-19-2007 01:57 PM
