Old 12-03-2012, 04:49 PM   #1
xnamerxx
0-60 in slow
xnamerxx's Avatar
Drives: light blue liftback
I measured 35mm for the port and 40mm for the gasket.
Old 12-03-2012, 05:39 PM   #2
NJ Drive
Drives: 2012 Yaris SE
Thanks. I have to be honest- the more I gather reading about 'bolt-on' solutions, I'd rather buy one of yours, assuming you find appreciable gains. I don't doubt that you will.
I intend to run a single hi-flow with a Burns muffler anyway, so might as well do it right.
NJ Drive is offline   Reply With Quote
Old 12-03-2012, 07:58 PM   #3
xnamerxx
0-60 in slow
xnamerxx's Avatar
I was once told by a GM engineer that the absolute best solution and absolute worse solution for exhaust is generally only a few % different. I've taken this advice to heart knowing the expected gains and losses can only be so much.
I do expect gains but the dyno and racing will be the true test if it actually works, I have simulation numbers, but those aren't always accurate to the real world.
If you want an easy/cheap solution ots parts work, but have the same design constraints production parts have, so you won't get the "best" solution. I can tell you this I noticed a significant loss of low-mid-range torque with the DC header while getting a size-able gain in topend torque. If you look at my dynosheet you can see that the DC produces a sizeable dip between 2700-3800 rpm, it feels really gutless out of slower corners but nice up top.
