#181 | |
#182 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 08 Yaris sedan auto / Fit auto Join Date: Oct 2009
" LOL , I was serious about the carfax thing. "
I'd hope you weren't yanking our dipsticks . Been awhile . How's it working out for you ? How about posting the CARFAX , if it's possible ( minus part or all of the V.I.N. ) . The more the merrier for those who disbelieve . |
#183 |
If possible post some pics of the oil that has gathered . Would be an easy task for you with the rack . No crawling under the car , standing room . Good luck .
#184 |
" well, I gave yari the "reach around" and snapped a pic with the GF's iphone.
Thanks for taking the photo . " seeping all the way down the timing cover. " This is how I found the '08 sedan with 17,893 miles and the 2010 3 door with 3,467 miles at the time of the O.C. for the sedan . Then checked the 2010 after finishing O.C. for the '08 . Also was on the top of the oil pan . Our friends 2010 3 door is very similar to yours . Have been monitoring that since last September . " There is no oil dripping from the car, but there is significant seepage extending all the way to the oil pan gasket. " Some oil would most likely fall to the ground when driving , due to it accumulating on the top of the oil pan . The dipstick for the 2010 would drop about 1/4" below the full mark by the time for next O.C. ( 4,000 + mis. ) . My next step will be removing the engine cover to rule out any spilled oil during O.C's, then trying to get a visual on the source, clean the whole area/engine down and run it for a couple hundred miles, then repeat. Good plan . " The oil is ready to be changed so I will also pull a sample to send to blackstone. That should tell the whole story. " It may . The U.O.A. I posted for the 2010 in the D.I.Y. forum shows no contaminants at 16,611 miles on the engine . The higher mileage you have could present an issue . Won't know until you send it in . " I will run a compression test " We never had that done . Did think of it . The oil comes from the #1 cylinder of the H.C.G. , cylinder 1 is closet to the timing chain ( you may be already aware of that ) . Be interesting to see if that is possibly lower than the others . Let us know your findings . " I am out of warranty " Not the case . You should be covered under the 5 year / 60,000 mile powertrain warranty . " I am hopeful that this is a " benign " head gasket seepage problem , and oil is only seeping externally . We'll see !!! " We're watching our friends 2010 3 door ( 70,000+ mis. ) to see if the H.C.G. craps out , hopefully not . May end up looking like this at 102,000 miles . Last edited by Hershey; 05-20-2011 at 12:03 PM. |
#185 |
![]() ![]() Drives: Axio GT Join Date: Apr 2012
Bumping this thread,as i recently discovered that a few 1nz fe have this leak.
A friend with the boosted TRD motor has the leak close to the timing chain cover and head/block region. Its nothing spectacular but the block is 'damp' with oil around this area. So what you you people have done? Replace the head gasket and torqued the head more? Or just replaced the head gasket? Thanks. |
#186 |
![]() ![]() ![]() ![]() ![]() Drives: no-longer-boosted '10 Yaris Join Date: Nov 2009
hate to be the one to bring an old thread back to life, but after removing my 2010 engine i took some pics. i think these will be the most clear pics in this thread and do point towards an issue with the head gasket sweating oil. Also possibly a new "ledge" to check for oil residue. Please keep in mind, i know i had an exhaust leak at my header, that is definatly not the cause of the residue. I will post more pics once i tear down into the engine more.
![]() ![]() Edit to highlight key points Green - Head gasket red - Oil residue (sweating gasket) area Blue - Exhaust leak RED ARROW - seating gasket, THERE IS NO OTHER WAY FOR OIL RESIDUE TO GET THERE ![]()
#187 |
Personally if I had this happen to me I would monitor the oil consumption very carefully.
Also I would put a piece of cardboard on the ground under the engine and park it there every night. If the oil didnt fall much on the disstick and there wasnt much oil on the cardboard, I would leave it alone! Theres more trouble to be had by strangers I dont know if they know what theyre doing taking apart the engine and "fixing" it. Also, who is to say a new head gasket WILL fix the problem? What if it doesnt? What if the well meaning people at Toyota screw something else up? If the compression goes south and the engine starts burning coolant that would be different. Does anyone know exactly were under the HG the oil is coming from? Maybe that can be modifyed? One thing bothers me is the reports of new Yaris's with overfilled crankcases. The oil needed is 3.7 qts probably they are putting four liters full in there. Could that do it?
#188 |
![]() ![]() Drives: 2010 5spd sedan Join Date: Nov 2012
This thread is painful to read, i'll be checking my block later... i did glance around there before i bought the car but now i'm going to check this specific area. Even if i am leaking, i would probably take bronsin's approach, i've had slow leaks on cars before that didn't cause major damage during the time i drove it.
#189 |
I say , let it be . Our friends' 2010 has the same leak since new and there's over 125,000 miles . Just check the level every week .
#190 |
I've found a few SCION XBs that have the same engine as the YARIS to have same oil leak . Not sure about the XAs . Rarely see those at used car lots .
#191 |
Hershey, lets not jump to conclusions and make a pandemic over something that isnt proven.
Please note i have been monitoring this since 2010 when i got my car and it was always existent but i never once noticed oil on the ground under my car, even after it sat for numerous days at a time. Also i never once noticed my oil dip stick dropped, even after i was boosted i only once noticed an oil drop and it was due to a seperate oil leak on a turbo line. another note, my car parks in the same spot every night in my garage, the same way. there has never been an oil drip on my white concrete floor. All that being said, this oil debris was visible on my 2010 yaris since about 4-6 months old (when i first checked) I do believe My car is not a perfect example as it was oil changed at the dealer since day one and im not 100% sure they did not ever "miss" the oil fill hole. i do believe if they were missing and some was running down the back of the engine i would smell a burning when it hit the header and also the chances of just missing enough to run down the back of the engine and stop on the ledge without going any lower is a long shot. I am comfortable in saying some of this collection of oil and debris could have been caused from oil change sloppyness but i am not able to say that all of this has been caused from oil change sloppyness. I will attach more pictures soon of the head gasket, from impressions in the head gasket i can say i did not see any failed points but the possibility of raw exhaust (carbon, oil, and other compression debris) blowing through the 2 piece layered head gasket. Calling this a "Leak" may be premature and incorrect, i am still leaning towards the gasket sweating out between them. Something else to note, the 2 head bolts on the timing chain edge did seem not as torqued down as the other bolts.
#192 |
I'm fine with it now . It's oil under the pan .
#193 |
#194 |
#195 |
Drives: 1997 yaris Join Date: Apr 2013
2007 w/ leak
Hey everyone,
Just wanted to report that my 07 Yaris Sedan (automatic) is having this issue. I am well beyond my warranty in years but not mileage. Warranty will not cover the issue. The fix was quoted as "Engine oil leaking from front cover, reseal cover, replace front crank seal & valve cover gasket" for which I am quoted the price of $502.00 + tax 1.) Is this really going to "Fix" the issue 2.) Is this price fair? Thanks for any help on the issue. |
#196 | |
#197 |
I'd let it slide for now . Clean the areas and watch . Check P.C.V. as stated above and replace if needed . Takes about 15 minutes to replace . Longer if stubborn . Use an closed end wrench to get leverage . May want to check the rear corner and the back of of valve cover on the passenger side . That could be a a culprit . Remove any residue in that area . Would also clean any oil from top of the valve cover that may been spilled during oil changes . Do this when checking P.C.V.. I use window cleaner to cut through oil resdue / grime . You'd be amazed how well it works . Paper towels used to remove grime / oil .
| best synthetic oil and m/t oil?? | doodoo | DIY / Maintenance / Service | 122 | 04-03-2017 08:43 PM |
| Transmission Oil for Yaris 1st Gen | adigilani | DIY / Maintenance / Service | 3 | 10-23-2011 02:48 PM |
