![]() ![]() ![]() Drives: 2012 Yaris SE Join Date: Nov 2011
Rotas lighter than Enkeis? That's just not right.
play every day
Drives: 2012 Yaris L 2dr 5sp Join Date: Apr 2012
These are the Rota RB specs for the same size as the 19 pound Enkei's:
Size: 16x8 Pattern: 4x114.3 Offset: +10mm Hub Bore: 73mm Weight: 16.55 lbs 2.4 pounds difference per wheel is a significant amount of rotating weight. My 15X7 RB's are 14.3 lbs. |
![]() ![]() ![]() ![]() Drives: 2010 Yaris Sedan Join Date: Oct 2010
Did you get them mounted yet? I'm anxious to see the whole effect of them on the car.
| Enkei Classic Series "Apache II"... | CanIHazYarisHatch? | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 37 | 04-04-2012 03:58 PM |
| enkei vs 5zigen for yaris sedan 07 | gudboi182 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 8 | 02-28-2012 01:27 AM |
| Rim Weights | bosbik | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 16 | 11-14-2009 06:42 PM |
| Classic shift knob from TWM Performance now available with engraved shift patterns! | TWM Performance | TWM Performance | 0 | 07-21-2009 10:57 AM |
