Old 02-27-2013, 02:30 PM   #1
Originally Posted by A1phazu1u View Post
Both good sir.
Really? I wonder if that is a sedan thing, as the liftbacks without power mirrors definitely are prewired. I wonder if anyone else with a non-power sedan has tried upgrading the mirrors?
To see the door wire connector you have to pull the door panel:
The switch connector was taped to the harness at the top of the under-dash fuse panel:
If you remove the driver's side kick panel and look at the bottom connector, do you have the black and sky blue wires on the top left of the connector shown here?
Old 02-27-2013, 11:06 PM   #2
nookandcrannycar
Is this the case for all model years re the USDM 2nd generation liftbacks?
Old 02-27-2013, 11:10 PM   #3
As far as I know - Yes. I know for sure that 08 and 09 liftbacks without power are prewired, but I haven't seen for sure with 07. If your 07 doesn't have power, check for the switch connector, as that one only requires popping the change cup.
MicZel has an 07 Sedan, that was a USDM Yaris that eventually made its way to Russia. His is pre-wired, as I am in the process of sending him a care package to convert his mirrors to power.
Old 02-28-2013, 02:48 PM   #4
Kar98
Drives: 2011 Scion tC
And what, good sir, would this care package contain, he asked, wondering how complicated it would be to convert non adjustable mirrors to power mirrors.
Kar98 is offline   Reply With Quote
Old 02-28-2013, 02:55 PM   #5
The package contained all kinds of goodies! For the power mirror conversion, literally all that is required (provided that you car is pre-wired) is the remote mirror switch ($50 to $100 depending on new or used) and about $40 each for good quality, new, aftermarket mirrors.
kuro-kuro, mga sarisaring katanungan xtremist Middle East 2740 01-27-2020 04:36 AM
Electrical System Upgrade Advice sqcomp In Car Entertainment + Electronics (audio / video / alarm) 6 03-23-2016 02:15 AM
Yaris Verso: Reset power window jam protection togo DIY / Maintenance / Service 3 01-10-2013 11:03 AM
DIY adding extra power outlets and usb power outlets on the dash to use phone as GPS julienrl DIY / Maintenance / Service 1 08-31-2009 11:06 AM
