Typically that means that it either is still not tight enough, or that while it was initially squealing the contact surface of the belt glazed (where the friction of it slipping caused the surface to melt enough to become too smooth to grip on the pulleys).
I have a Dayco belt on my red Yaris, that I grabbed because it was the only thing in stock at the store that I grabbed it from. I have had to tighten it three times since the initial installation.
#2 | |
![]() ![]() ![]() ![]() Drives: toyota yaris yrs Join Date: Jun 2007
Thanks Scotty mate. |
![]() ![]() Drives: 08 Yaris AT, 350Z GT MT Join Date: Feb 2013
Though the proper tension is required, did you check the pulleys for damage?
Specially the water pump one, I found mine damaged while replacing the belt. If you used WD-40 in the alternator lower bolt, I suggest spraying the area with a mild degreaser then flush it with water. Last edited by hw6515; 03-02-2013 at 05:54 PM. |
Yeah, my water pump pulley is glazed it looks like that pic.Thanks for the info
man. How much does a new one cost? |
#5 | |
Got the Water pump and the pulley from Amazon. http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1 http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1 |
![]() ![]() ![]() Drives: 08Yaris2D, 88LandCruiser. Join Date: Jan 2013
Pry bar ftw..It seemed to do the trick.Success! Thanks critic..
#8 | |
![]() Drives: . Join Date: Oct 2011
| Seat belt buzzer is silenced | billk | General Yaris / Vitz Discussion | 48 | 10-30-2013 09:58 AM |
| new serpentine belt | dferguson2 | DIY / Maintenance / Service | 1 | 06-30-2012 08:07 PM |
| The Accessory belt? | N9QGS | DIY / Maintenance / Service | 4 | 02-12-2009 11:05 PM |
| Rough Idle in drive | toyoman | NY / NJ/ CT / PA | 8 | 04-22-2007 03:40 AM |
