Old 03-08-2013, 03:43 PM   #1
42ezra
Drives: 2010 2dr MT Liftback
The rocker panel has very limited access, with there being a couple of small (<1/2") holes that are taped over and a very small access area at the base of the B Pillar, where the seat belt is mounted. It may actually be the ball bearing from the seat belt assembly. There is one in a plastic assembly that makes the seat belt stay taught when it is upside down.
Thanks CTScott. I'm going in through that opening behind the passenger seat belt assembly with a bent coat hanger. I have to get rid of the thing. Driving me nutz! Thanks for your advice.
42ezra is offline   Reply With Quote
Old 03-08-2013, 03:59 PM   #2
If you can't get it pop down to Southbury some day and I'll give you a hand.
DIY for Steering Wheel/Airbag Removal? MGargano DIY / Maintenance / Service 5 03-01-2019 02:21 AM
DIY Rear Drum Brake Adjustment/Parking Brake W/ PICS Inside YarisSedan DIY / Maintenance / Service 73 03-11-2017 06:05 PM
Rear Window Removal idipudipwedip2 DIY / Maintenance / Service 1 03-27-2009 05:09 AM
