![]() Drives: toyota yaris 1.0 t3 2004 Join Date: Feb 2013
well i will never ever find tht out...as it was a recent private buy and I spotted that within couple of days after buying the car, but did not knew if it was a hole to be closed or just some pressure relieving hole. But when the gear popping problem started, I got it checked from the garage n was told gearbox fkd n need replacement I stopped using the car and wondering what to do as the replacement cost was huge. then I started the thread here, kou 's pics helped me and made my doubt clear that its the filler plug hole n must be closed. rest is history buried in this thread.
yarisworld rock.
GRADE: TRSTD: STANDARD TYPE (02/2003- ) PRODUCT: FRP: PRODUCED AT TMMF DRIVER'S POSITION: RHD: RIGHT-HAND DRIVE ENGINE: 1SZFE: 1000CC 16VALVE DOHC EFI TRANSMISSION: MTM: MANUAL TRANSMISSION GEAR SHIFT TYPE: 5F:MTM, 5-SPEED FLOOR SHIFT NO.OF DOORS: 3D: 3-DOOR COLOR CODE: 1E7 TRIM CODE: FC11 |
Did you change the oil in there?
If not drain the old stuff out and fill with new. If the oil that came out is dirty/has junk in it report back here for further instructions...
| Tags |
| gear pop jump neutral |
| Experimenting with bypassing the AT 4th gear prohibition when cold | CTScott | Performance Modifications | 28 | 03-22-2015 08:16 AM |
| Remote Start Problem: Mechanical, Like in Gear | Lil Abner | DIY / Maintenance / Service | 10 | 07-24-2011 06:49 PM |
| Toyota C160 Reverse Gear Problem | Parmas | DIY / Maintenance / Service | 2 | 12-01-2010 01:30 AM |
| Gear oil change choices (Canadians) | Jem_hadar | DIY / Maintenance / Service | 17 | 08-29-2009 11:51 AM |
| New Owner - Lights on Gear Shift | javagirl | New YARIS Purchase Forum | 8 | 05-22-2009 02:23 AM |
