![]() ![]() Drives: 2006 Toyota Yaris RS Join Date: Feb 2007
Yikes.... Regardless of your results, I would NOT follow any of the advice given.
First and fore most, when applying a degreaser your engine should actually be warm to the touch prior to application. Depending on how harsh of a degreaser you use, the time of "soaking" will vary of course before rinsing it clean. Also the fact that you're misusing in extremely excessive amounts, products that are ment for interiors and tires on your engine is horrible detailing etiquette. Have you ever noticed what occures to your tires with the use of most tire "sheen" products? (there are exceptions of course) Due to the heat, they actually end up turning rubber a nasty brown/yellow colour after time.... would you honestly want that occuring with all the rubber components of your engine, such as mounts, hoses, etc.? Lastly, once soaking up the majority of water after washing an engine bay, you can actually let the car run for a said amount of time to quicken the drying cycle. |
#2 | ||||
YRS WHOR
Drives: White 2007 Yaris E-Limited 5dr Join Date: Feb 2007
![]() Quote:
Image1.jpg Image2.jpg Image3.jpg Good advice, thanks! |
#3 | |
#4 | |
![]() ![]() ![]() Drives: 03 Toyota Corolla S modded, Join Date: Jan 2007
Well... its an old honda civic "93" my buddy used to own... well I sprayed that "solder seal" engine degreaser when he came to my place and ask me to wash it bcoz his going for a group meet, so I hustled and sprayed it with E.D. and about 3 seconds after I sprayed it, nasty smelling smoke came out... then I hit the freakin header! and it went to flames! quickly he grabbed his "NOS lookin" fire extinguisher and sprayed the hell out of it! the engine lining he installed got melted a bit and he told me to just stop it... and he just went to the club meet with a nasty lookin engine with a burnt hood padding... what I'm saying is some cars need the engine cold just to clean it safely...
THE YARIS: TINY BUT PRICEY! BUT YOU JUST GOTTA LOVE IT....
Why degrease an engine that isn't greasy? As a note, those degreasers are powerful, so be careful not to get them into parts with bearings (ie. the alternator pully, A/C compressor pully)...
I just use low pressure water every time I wash the car and my cars stay nice and clean under the hood. Yes, I'm careful where I spray. I would only clean under the hood by this method if I were tring to sell the car. Your pictures look great! |
#6 | |
YRS WHOR
YRS WHOR
The Camry will be fine as well.
As for the belts, it's simple - look at them, understand where they are, then don't spray any dressing/protectant on them :) The engine cleaner and the water don't pose a problem for your belts. Are you allowed to use a watering can with the water restrictions, or are all forms of car washing prohibited? If a watering can can be used, that'll probably do the job - you're really only rinsing off the engine cleaner. |
#9 | |
Lil White her name is ~
Drives: White YRX 5DR Hatchback 2006 Join Date: Dec 2006
Thanks for the help ^_^ ~ Jaspie ~ |
YRS WHOR
car plate? 'sif you'd go to the trouble of letting speed cameras get a good shot of your car if you're not allowed to wash the rest of it :P
![]() ![]() ![]() Drives: '00 Toyota Celica GTS Turbo Join Date: Aug 2006
Sweet! Is that the stock engine cover or did you add stickers to the VVTI part to make it red?
#14 |
YRS WHOR
Red was standard on mine..
#15 |
yup, for some reason it looks like all 1NZ engine covers have some red VVT-i lettering over here...
The red color alone must bring the engine's power up a few horsepower!
#16 |
YRS WHOR
Well actually I've seen the Thai market Yaris rated at 109HP, while the North American Yaris is rated at 107HP, so there might be some truth in that.. or maybe someone just made an error in the conversion from kW
#17 |
Dude there's like 5 different actual horsepower units and methods of calculations. PS, BHP, HP are the most common, but most end up within about 5% of each other, so it's not too bad. I think this is the cause of this slight difference in ratings
![]() PS. For more information: http://en.wikipedia.org/wiki/Horsepower
#18 |
![]() Drives: Getting a Yaris soon Join Date: Feb 2007
I brought my car into the shop once and the guy did it for me (since at the time I had no clue how to do it myself...)
He kept the engine running, put a plastic bag over something, sprayed a whole can of degreaser, then hosed everything off...
MDF Yaris: I live my life a quarter mile per gallon at a time... |
