Im planning to wash down my engine bay.... Just wondering, do I need to cover any part before applying the degreaser, or just go ahead, rinse, appply degreaser and rinse and wipe?
cover your AFE intake , and go for it
I did this when i had my ford escort. And then the car ran like crap afterwards cause i burnt out a coil.
pink wheels are cool
fixed it for you
Half a Bubble Off Plumb
The stock Yaris air intake curls up like a ram's horn in front of the air box, behind the bulkhead that holds the radiator, on the driver's side. Don't spray water straight into it.
As for horsepower ratings, those are nominal anyway. You'll find considerable variations between individual cars of the same model, and with the same car from one dyno run to another. What you normally measure on a chassis dyno, that is really put from the wheels to the road, is a good bit less than the manufacturer's engine HP rating. Not worth quibbling over a few digits on the rating.
![]() ![]() ![]() ![]() ![]() Drives: LB-Auto-PWR-ABS-Cruise-Springs Join Date: Aug 2006
You can use Simple Green instead of the engine degreaser and a sponge and wash it carefully. Then dry and do the tire shine treatment. Awesome results Razr!
Other car is a 2005 Mustang Convertible 4.0L V6 Manual - Legend Lime Get YarAss in gear! RIP - Casey Tatum |
#8 | |
Learn to Relax
![]() Drives: Toyota Yaris Sedan 08 Join Date: Apr 2009
should i cover the rotor and battery while hosing it down?
![]() ![]() ![]() Drives: '08 5-door Join Date: Apr 2009
#11 | |
i dunno what its called it looks round and metal (description doesnt help) anyways is there anything or part i need to be aware of while hosing the engine bay with water? |
I think it would be wise to put a plastic bag over the alternator. I also would leave the engine cover on to avoid a build-up of water where the plugs etc sit. That's me though. I never have with intention sprayed my engine with water for cleaning purposes. Last, not wise to do a hot motor.
VVTi lover | D-4D driver
Drives: 1.6 Corolla & 1.4 D-4D Yaris Join Date: Oct 2008
I hate dust and dirt on the engine cover...! I'll take a picture of mine, ass soon as I stick the little "Toyota" badge on it, and paint it all flat black! :P
(2006) - 1.6 VVTi Corolla & (2008) - 1.4 D-4D Yaris |
so after the rinse and dry with rag, how long should you wait to start the car? ive cracked a block before cleaning the engine, though it was a 25yr old car and had no protection against water for the most part. but just want to make sure i dont ruin anything. thank you
![]() Drives: white yaris Join Date: Aug 2010
do we need to cover somestuff?
#18 | |
USAF_SrA_E-4
BUMP for others asking on how to do this
