The fill plug was missing?
Serious stuff! I doubt there is anything you can do except rebuild the transmission or get one in a junk yard. But I might be wrong.
#2 | |
![]() Drives: toyota yaris 1.0 t3 2004 Join Date: Feb 2013
But my question is if there is any filter that needs to be changed as well during gearoil change??
GRADE: TRSTD: STANDARD TYPE (02/2003- ) PRODUCT: FRP: PRODUCED AT TMMF DRIVER'S POSITION: RHD: RIGHT-HAND DRIVE ENGINE: 1SZFE: 1000CC 16VALVE DOHC EFI TRANSMISSION: MTM: MANUAL TRANSMISSION GEAR SHIFT TYPE: 5F:MTM, 5-SPEED FLOOR SHIFT NO.OF DOORS: 3D: 3-DOOR COLOR CODE: 1E7 TRIM CODE: FC11 |
#3 | |
You are right change the oil. You might find metal flakes in the oil. Or you might not. Not is good! One trick we used to do with a transmission making noise/popping out of gear was change the oil and add a tube of molybdenum additive. But change the oil and DRIVE THAT SUCKER! If it still pops out of gear my experience (with old VWS) tells me the trans will eventually go. But that might be a long time from now. In the meantime you can further evaluate the car too see if you want to put more $$$$ into it. And find a transmission in a junk yard. Good luck! Tell me what happens!
Thanks Bronsin.
do you have any product code/brand etc for this additive "add a tube of molybdenum additive.", and how much you recon to add? Also there is another link i found about the gear pops: http://www.mr2.net/trackdayqueen/fithgear.htm But donot know if the 5th gear is also accessible similarly in yaris?
#5 | |
Or ask at a local parts store for the same.
| Tags |
| gear pop jump neutral |
| Experimenting with bypassing the AT 4th gear prohibition when cold | CTScott | Performance Modifications | 28 | 03-22-2015 08:16 AM |
| Remote Start Problem: Mechanical, Like in Gear | Lil Abner | DIY / Maintenance / Service | 10 | 07-24-2011 06:49 PM |
| Toyota C160 Reverse Gear Problem | Parmas | DIY / Maintenance / Service | 2 | 12-01-2010 01:30 AM |
| Gear oil change choices (Canadians) | Jem_hadar | DIY / Maintenance / Service | 17 | 08-29-2009 11:51 AM |
| New Owner - Lights on Gear Shift | javagirl | New YARIS Purchase Forum | 8 | 05-22-2009 02:23 AM |
