Old 03-26-2009, 04:29 PM   #1
NonStopTuning
Originally Posted by DogTony View Post
I do understand how the crank pulley works but still can't fully comprehend the applications of alternator/water pump pulleys. what do they do?
i'm living in bangkok thailand so the temperature is very hot. the life of the air con and its function are very crucial to me also. if i replace the alternator/water pump pulleys, will this affect the air con??
thanks for your reply in advance.
The ALT & WP Kit includes two pulleys that are the same size as the OEM pulleys they replace. The NST versions are roughly 70% lighter than the OEM pulleys and this weight reduction leads to better throttle response, quicker acceleration, and better MPG.
No one using NST pulleys should be worried about the performance of the a/c, the alternator, the water pump, or any other accessory. We take the performance of all accessories very seriously when doing our research and development. We build products that will provide you with excellent performance gains, while keeping ALL your accessories functionality in tact.
Go with NST and go happy
MIKE @ NST
www.NonStopTuning.com
Old 04-01-2009, 12:49 AM   #2
NonStopTuning
Anyone else?!
Old 04-01-2009, 02:17 AM   #3
Astroman
Modded Moderator
Astroman's Avatar
I've put over 50k miles on my crank pulley, and at least 40k miles on the WP and ALT pulleys and they are still making me smile
Old 04-01-2009, 02:53 PM   #4
NonStopTuning
Thank you Astroman
Old 04-01-2009, 03:43 PM   #5
hatchbackkid82
Drives: .
Has anyone who has the crank pulley installed had any problems? You know the whole damper vs no damper debate. Debating whether i should should get the crank pulley or not.
Old 04-02-2009, 12:40 AM   #6
NonStopTuning
20 pages of firsthand reviews and reports in this thread alone. Many other threads of similar content all over YW. Hundreds of reviews, 100% of which have been positive.
The following forums also have THOUSANDS of user reviews from people who have owned and used NST pulleys on their cars over the past several years. Zero reported cases of engine failure due to NST pulleys...
www.YarisWorld.com
www.ScionLife.com
www.8thCivic.com
www.XR-Underground.com
www.MicroImageOnline.com
www.86garage.com
www.club4AG.com
www.tsxClub.com
etc etc etc.
Old 04-02-2009, 09:11 AM   #7
hatchbackkid82
Drives: .
Don't get me wrong i wasn't questioning the quality of the product. I'm pretty sure the pulleys are great. Just thought i would ask. Thanks for the info though, looks like i'll be purchasing these in a few weeks. Just had a honda tech tell me a few years ago that crank pulleys blow oil pumps.
www.YarisWorld.com
www.ScionLife.com
www.8thCivic.com
www.86garage.com
www.club4AG.com
www.tsxClub.com
etc etc etc.
Old 04-02-2009, 02:28 PM   #8
NonStopTuning
Thousands of pulley users on http://www.8thCivic.com over the past few years... Zero cases of bottom end failure or oil pump failure when NST pulleys have been used.
MIKE @ NST
Old 04-03-2009, 02:46 AM   #9
wsladaritz
Y4R1Z
wsladaritz's Avatar
Drives: Yaris LB
So I was looking on the NST site and there are three different kits for the yaris. Two of them are sold out though. Which kit should I be looking at? Which would be most beneficial for a daily driver just looking to add a little more pep?
wsladaritz is offline   Reply With Quote
Old 04-03-2009, 02:30 PM   #10
bikegerm
bikegerm's Avatar
Drives: 2007 Meteor LB
As The Pulley Turns.....
Mine just arrived today!! A complete Red Power Pulley Underdrive set for my liftback. Problem is, they're lonely. They are here but the Yaris is with my wife visiting her family 350 miles away. So close, yet so far... I'll let you know when they find each other and how their relationship develops.
Randy LeRoy
www.airshowmastering.com
randy@airshowmastering.com
bikegerm is offline   Reply With Quote
Old 04-03-2009, 03:58 PM   #11
NonStopTuning
AWESOME
MIKE @ NST
Old 04-03-2009, 04:01 PM   #12
NonStopTuning
You can read through the many pages of this thread, as your questions have been answered many times, in much detail.
Short version...
If you plan to stay naturally aspirated you should use
NST09010 plus NST09025K
If you plan to go supercharged you should use
NST09158 plus NST09025K
We are currently sold out of our crank pulleys (till May 2009), but you should be able to order these pieces from MicroImageOnline.com
Good luck and have fun with all your projects
MIKE @ NST
Old 04-03-2009, 04:24 PM   #13
hatchbackkid82
Drives: .
Sorry to be a NOOB, looking to buy a pulley kit what's the difference between the 10% Underdrive kit and the CR-lite pulley kit?
Old 04-05-2009, 06:31 AM   #14
NonStopTuning
Short version...
MIKE @ NST
Old 04-04-2009, 05:56 PM   #15
i dont feel like reading the whole thread, but i put on my underdrive pulley yesterday and had to buy a new belt that was 355mm long vs the stock 360mm....
belt was too long otherwise...wouldnt get tension in it..
mine is a 3dr w/o air conditioning...
might be worth noting...
Old 04-04-2009, 05:58 PM   #16
auxmike
auxmike's Avatar
No A/C? I thought it came standard?
Old 04-08-2009, 01:12 AM   #17
any comment from NST?
Old 04-08-2009, 03:48 AM   #18
NonStopTuning
I'm not quite sure what type of comment would be warranted here.
Unfortunately we have never tested with any Yaris that did not have a/c. And as far as I can tell, you are our first ever customer to use one of these pulleys on a Yaris that has no a/c.
Based on past experiences with other cars I can see how you may need a slightly shorter belt with your setup and it sounds like you have found your solution.
Buying a new belt is a small price to pay in exchange for picking up a few extra ponies
Any other owners out there running around with no a/c, please feel free to comment.
MIKE @ NST
