Old 04-09-2013, 10:03 PM   #1
Originally Posted by dinop View Post
I just need to ground it to the body?
I can't find a kit anywhere that has the headlight feature. My friend has a volvo that does what I'm looking for. When you press the yellow button on the key fob, the lights come on for about a minute. I didn't think it'd be too hard to do, but I guess it is. I'd make my own transmitter and receiver, but I have no background in electronics. Any suggestions?
Many keyless entry systems have an extra button that triggers an auxiliary function. It can be used for anything from turning the defroster on to popping the trunk. That's what you would use to do your Volvo emulation.
Old 04-11-2013, 09:15 AM   #2
dinop
dino
dinop's Avatar
Drives: '07 Toyota Yaris (sedan)
A friend gave me this keyless entry/remote starter kit last night, and it does have an auxiliary function, put it only puts out positive power. I'm thinking of skipping the headache and putting the factory keyless entry (for the two door hb) in my sedan since the remote is shaped for the guts of a toyota key anyway. Any resources you would recommend for parts/diy installation?
The high-mileage club is like the mile-high club...in no way
Dino, VT
07 Toyota Yaris Sedan- stock, 281k, daily driver
09 Toyota Yaris Sedan- stock, 128k...parents car
95 Audi S6- alt daily driver, 5 cyl turbo, 224k
75 Triumph TR6- Current restoration project, 8k
dinop is offline   Reply With Quote
Old 04-11-2013, 09:27 AM   #3
There's a thread on here where all of the parts required are listed. You'll have to do a bit of searching to find it. The part though are very expensive for an OEM keyless install, as you need the receiver (which is very hard to find and crazy expensive when you do) and the body ECU (which is part of the under dash fuse panel).
delayed headlights, flip key, keyless, remote, trunk release
Help with replacing 2 button key remote hotnoodle DIY / Maintenance / Service 22 12-18-2016 06:26 AM
Transponder key programming teddy DIY / Maintenance / Service 6 04-28-2015 07:32 PM
Lost key (transponder and remote lock/unlock) shyeoh DIY / Maintenance / Service 4 07-11-2013 06:04 AM
Yaris 2012 Sedan Key with remote faisalloe General Yaris / Vitz Discussion 5 09-27-2012 11:29 PM
Need remote key fraenx DIY / Maintenance / Service 1 06-26-2009 08:29 PM
