Old 04-10-2013, 04:03 PM   #1
shaunsm_uk
Drives: Yaris 1.3
Hmmm could it be the ignition switch, do you have a wiring diagram or pinouts for them?
shaunsm_uk is offline   Reply With Quote
Old 04-10-2013, 05:11 PM   #2
Yes. That's where those wire colors I mentioned to check come from. Those two wires are all that goes through the ignition switch that is related to the coils.
Old 04-11-2013, 04:08 AM   #3
shaunsm_uk
Drives: Yaris 1.3
Just checked the ignition switch as the attached pic, the thinner wires on the right of the connector white/brown is the 12v feed, with ignition on the black/red wire has 12v and on trying to start the black wire also gets 12v
On the left side of the connector thicker wires 12v feed comes in on the white/blue opposite the thinner black cable, and the other two get 12v when switch is turned to on position, so I'm pretty confident the ignition switch is ok?
Where do I go from here
yaris won't start, engine truns over but won't start. zara616 General Yaris / Vitz Discussion 16 09-05-2021 11:39 AM
Yaris starts then it wont start. wush11 General Yaris / Vitz Discussion 18 01-05-2011 11:53 AM
Let's start a Yaris Club, each member has a specific number decal Yawesh General Yaris / Vitz Discussion 48 04-10-2009 10:49 PM
