Only Happy When it Rains
I had mine changed at about 55k miles, or about 88514km. Really though, keep it until it is obvious it is hurting gas mileage, my gas mileage dropped 5 mpg, for no reason. Changed the transmission fluid, it went back to normal.
Dirty transmission fluid will negatively effect gas mileage. Even doing the drain and fill by hand a little bit every year or so is better than leaving dirty transmission fluid in there.
Colin Chapman disciple |
PlayToWin
Drives: 2008 Toyota Yaris Sedan Join Date: Apr 2013
Thanks for the responses. I'm wondering is there anything special about an automatic versus a manual that makes the fluid change less necessary?
Automatics have "wet-clutches" meaning that the clutches are inside the case, and in the fluid. As the clutches wear, the grit ends up suspended in the oil, and in the filter if bad enough. They also create heat, which breaks down oil. Modern automatics are much better than older ones, but still do both of these things.
Theres like two quarts of oil in a Yaris manual transmission and three times that in the automatic.
Crazy Russian
Drives: 2007 Yaris RS Join Date: May 2013
Going to drain and fill ATF on my 2007 Yaris with 106k kms on it.
Will fill with Mobil synthetic ATF. Update: Desided not to )) Ordered 6 jugs of Eneos... much better than Mobil. Lower Viscosity = 5.7 Last edited by Everglade; 05-24-2013 at 03:13 AM. |
![]() Drives: Yaris LE 2014 Join Date: Feb 2016
Go purchase Toyota WS fluid plus one more court than your car will hold.
1. Drain the pan. 2. Refill the pan with exactly the same amount you drained. 3. Locate and remove the fluid return line from cooler to transmission. 3. Remove it and drain into graduated container. 4. Start the car, drain out the balance of the fluid as you add the new fluid. 5. Reconnect the return line, top off the fluid to proper level. (As an added benifit you can also change the filter if the fluid is really dirty and burnt). This will get most of the fluid out of the car cost effectively. |
![]() Drives: 2008 Yaris 2-Door (White) Join Date: Jan 2014
Did a drain/fill on my wife's 08 Yaris a few weeks ago at about 52,000 easy miles, and the fluid came out brown; no burnt oder, just discolored. Because of this, I decided to do another drain/fill and to change the filter at the same time. On that drain, the fluid was red, but not clear, so the second change will help some more. I'm used to Hondas where I have always changed (drain/fill) the ATF at 25K-30K intervals, and it always comes out clear red. Even though Toyota says the fluid is supposed to last the life of the car, I would recommend the same 25K-30K drain/fill maintenance for the Yaris too.
![]() ![]() Drives: 2015 yaris Join Date: Aug 2015
my 2015 has a drain plug and removable pan.wonder if the converter has a drain like some do?
![]() ![]() ![]() Drives: 2009 Yaris Join Date: Jan 2014
no
![]() ![]() Drives: Yaris 12 Join Date: Oct 2016
If you drain and refill with the same amount, do that 3 or 4 times (once a week), after 4 times you will have change about 95% of the oil.
| Yaris Oil Change DIY | rningonfumes | DIY / Maintenance / Service | 91 | 01-11-2019 07:18 PM |
| Tutorial : Speaker Changing, Headlight Painting, Center Control Colour,Panel Removal | hasher22 | DIY / Maintenance / Service | 88 | 03-06-2014 06:40 AM |
| transmission fluid that indicate must change | susucosp | DIY / Maintenance / Service | 3 | 12-10-2011 11:51 PM |
| Carbon Buildup = Fuel Injection Flush??? | zfarsh | DIY / Maintenance / Service | 24 | 10-30-2011 03:55 PM |
| MJ dead | 90tsi | Off-topic / Other Cars / Everything else Discussions | 28 | 06-26-2009 02:20 PM |
