Old 04-25-2013, 04:01 PM   #1
mr_miles
Drives: 2013 Yaris
Ah - your TB is also turned 45 degrees compared to mine, hence me not seeing the lines :p I have the chip on the side, instead of the top. Shouldn't affect it in any way depending on how that's faced, should it? My cold start is 3k, guess it's time to adjust that idle screw!
Old 04-26-2013, 02:07 AM   #2
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
Yes. Offsetting the bolt holes in the adaptor to miss the ones in the manifold necessitated some rotation...
Luckily it's fly by wire so no linkage issues are created.
Nope.
It's just a variable valve metering air.
You'll be glad you did even though it's a tedious task. Try backing it off one full turn at first, and then fine tune it. When your cold idle begins at 2,100 right at start up, your hot idle should be just right.
any person swap 1zz in yaris hb? IVAN_TRD Performance Modifications 18 09-07-2014 11:19 AM
AFE short ram intake in 3rd Gen DJYojimbo Third Gen Yaris General Discussion 10 12-20-2012 09:25 PM
Tanabe R&D Session on the 3rd Gen. vitz_flava Third Gen Yaris General Discussion 2 06-07-2012 05:52 PM
1zz swap...is it worth it??? jouna Performance Modifications 12 11-10-2009 09:33 PM
