Old 05-02-2013, 01:06 PM   #1
07stlYaris
If Its Not Blown It Sucks
07stlYaris's Avatar
Drives: 07 Yaris LB Meteorite
Gettin' Blitz'ed and have a question...
Curious if the standard injectors are sufficient with the Blitz S/C (and Blitz management)? I have a set of 1ZZ injectors and am wondering if I should swap them while I'm already up to my elbows. Thanks in advance for the reply.
07stlYaris is offline   Reply With Quote
Old 05-02-2013, 03:20 PM   #2
TOLMACH
Drives: soarer
My opinion is that 1NZ injectors are totally sufficient.
Old 05-02-2013, 03:56 PM   #3
47_MasoN_47
What I thought I'd do was
47_MasoN_47's Avatar
Drives: 09 Yaris Sedan
I was running lean with 1NZ injectors, but I have an AFe intake. The Blitz is designed to be fine if you have the factory airbox, but if you've got an aftermarket intake then go with the 1ZZ.
Old 05-02-2013, 04:49 PM   #4
07stlYaris
07stlYaris's Avatar
I've had an AFR gauge installed for a year now just waiting for the chance to get boosted. I'll probably swap the injectors out and wait for the CEL. I have a CAI (custom) and a full 2.5" exhaust (custom as well) so I expect with that kind of flow I should be ok with the 1ZZs. I'll update so others will have a reference point.
Old 05-02-2013, 05:11 PM   #5
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
Good to know. I'm starting with the stock airbox and exhaust, but with a K&N drop-in filter. CAI and exhaust are in the near future, so I'll have to figure in the cost of injectors too.
Old 05-03-2013, 11:45 AM   #6
47_MasoN_47
I got my 1ZZs on ebay for about $60 shipped.
Old 05-03-2013, 11:47 AM   #7
47_MasoN_47
Actually here's a set buy it now for $60 or bid starting at $35 + free shipping.
http://www.ebay.com/itm/4-Corolla-Ma...53922e&vxp=mtr
Old 05-03-2013, 12:32 PM   #8
kou
Drives: 08 lb
Here is a good site for denso injector info. http://witchhunter.com/injectordata1.php
Old 05-03-2013, 12:52 PM   #9
Toy_Yoda
Drives: 2006 Scion xb
Hope ya don't mind a Scion Xb owner jumping in, but on a somewhat related issue, will the stock fuel rail be adequate or is an upgrade recommended.
Toy_Yoda is offline   Reply With Quote
Old 05-03-2013, 12:53 PM   #10
kou
Drives: 08 lb
Stock fuel rail is fine unless you want some extra bling.
Old 05-03-2013, 01:02 PM   #11
Toy_Yoda
Thanks for the swift reply. It's gonna be pretty much hidden by the blower case anyway. Just picked up a used Blitz Tuesday and must say you Yaris guys have it together with a whole sub-forum devoted to forced induction!
Old 05-03-2013, 01:05 PM   #12
kou
Drives: 08 lb
Your welcome. And scion xb's are more than welcome here.
Old 05-03-2013, 01:16 PM   #13
Toy_Yoda
The Blitz is gonna put me in the unusual position of actually looking forward to my next smog inspection so I'll have another two years to play around. Comes due next February. Hope I can avoid the temptation to start the install now and get it really dialed in just in time to pull it all off for the the inspection.
Old 05-03-2013, 11:41 PM   #14
I put 1zz injectors in mine....the fuel rail has to be loosened/taken off anyways. Then if you upgrade I/h/e like I had on mine, you'll want the extra fuel so you don't run lean
Old 05-04-2013, 03:38 AM   #15
Toy_Yoda
Now you have me wondering about the stock fuel pump. Is it adequate for the demands the Blitz piggie-back fuel management is gonna place on it?
Old 05-04-2013, 07:34 AM   #16
The fuel pump is more than adequate for up to about 12psi of boost. If anything one would ideally like to upgrade the pressure regulator to compensate for the increased plenum pressure from the boost. I did an experiment with crimping the OEM regulator to increase its cut-off by 6 psi to match the max boost of the Blitz. Ideally one would want the pressure increase to be a 1:1 ratio with the boost, but the crimp method is an easy fix, which doesn't require the significant mods to the fuel system that an adjustable regulator would.
Old 05-04-2013, 02:20 PM   #17
07stlYaris
07stlYaris's Avatar
Could you explain the crimp or is it in another thread? Thanks.
Old 05-04-2013, 09:49 PM   #18
There is some thread where I discussed it, but I have no idea what or where it is. You simply take the regulator, stick a socket over the top end (to protect it), and put the whole thing in a vise. You gently squeeze the bottom end (against the socket on the top) to increase the crimp and hence tighten the spring. You really need a rig to test it with though to verify the adjustment.
Here's a video of the test setup that I put together that let me easily test the tweaked FPR:
http://www.youtube.com/watch?v=pH3mev88hoo
