Old 06-08-2013, 12:03 PM   #1
Howster
Drives: 2007 Yaris 4-door
Hi and thanks for the replies. I have totally cleaned the injectors, replaced the o-rings and caps, replaced the plugs, and so much other stuff I can't remember it all. However it was all done via troubleshooting and not just a way to replace things for the heck of it.
Everything needed to be done as it had not ever been done. I am still concerned as to why the car shuts off when the a/c is turned on. Once I figure that out the rest should fall into place. Thanks.
Howie
Howster is offline   Reply With Quote
Old 06-08-2013, 12:18 PM   #2
Howie
The AC obviously puts a large load on the engine. The Yaris ECM does not compensate as much for this at idle as most other cars' ECMs do. So, if you are having fuel delivery issues they will be amplified with the AC. You may wan to try pulling the coil connectors and disconnecting the fuel rail and turning the engine over while letting the fuel hose squirt into a container to see what the flow looks like.
What Car Mechanics Don't Want You to Know!! daddz07 DIY / Maintenance / Service 16 04-17-2011 11:10 PM
Zefoxe - Photo Scavenger Hunt Zefoxe Photo-Video-Media Gallery 0 03-02-2009 11:23 PM
Arkhangel - Photo-Scavenger Hunt Arkhangel Photo-Video-Media Gallery 0 03-01-2009 03:03 PM
