03-04-2012, 10:51 AM | #73 | |
der Zeck
I just did an BBK using OE parts as well stock fronts were 288, I found 325mm off an A6 stock rears were 245, I found 300mm A4 Conv cool thing was I got to keep my calipers, only had to replace rotors and caliper brackets, and I threw a fresh set of Euro spec pads
10-05-2012, 02:50 PM | #74 |
update on bbk, did a checkup after 30k miles and the brake pads are still pretty damn new. everything is working fine and wearing nice and even.
10-25-2012, 04:06 PM | #75 |
Drives: Toyota Yaris Sedan 09 STD Join Date: May 2009
Nice!
10-25-2012, 04:15 PM | #76 |
Form>Function
Awesome another brake option.
07-08-2013, 09:48 AM | #77 |
Just upgraded mine over the weekend. My first brake job on the yaris 102,000 and still had some pads left but warped rotors. Total cost $380 OEM pads for 2009 corolla rebuilt calipers for 2009 corolla and rotors from the yaris se. Wheel size is 15x7 et42.
07-08-2013, 10:20 PM | #78 |
Woo!! 2 in the northeast! now go persuade james to do it lol
07-08-2013, 10:37 PM | #79 |
07-08-2013, 10:38 PM | #80 |
i'll keep a look out for you.
07-08-2013, 10:41 PM | #81 |
Camry Owner
AWSOME!
02-05-2015, 05:17 PM | #82 | |
HacKers WanTed!
Drives: Yaris S HB & Yaris S SD Join Date: Aug 2007
Think I'll swap the master cylinder also! Corolla and XD are they the same?
R-CaT Project Yar 2ZR |
02-05-2015, 06:37 PM | #83 |
47201-52420 -> scion XD
47201-02490 -> corolla XRS 09 |
02-05-2015, 06:45 PM | #84 |
HacKers WanTed!
will they mount properly on the Yaris is the question, for a rear disc swap corolla XRS should be the best
02-05-2015, 09:08 PM | #85 |
most likely not lol.
you *MIGHT* get away with using the scion's master cyl, and i know the brake booster off an xd will plug right in... 44610-52620 the XRS booster assy looks sooo different. 44610-02441 |
02-06-2015, 09:09 AM | #86 | |
HacKers WanTed!
Since I'm on this let me update info Yaris rotor 8lbs Yaris SE rotor 10lbs Yaris caliper 13lbs Corolla caliper 15lbs So for rotating mass there's a 4lbs increase and in overall car weight its 8lbs Sent from my iPhone using Tapatalk
04-23-2015, 05:36 PM | #87 |
Drives: 2012 Yaris 5dr Hatch Join Date: Oct 2014
Just picked up a new set of 2011 calipers, se rotors, apex lines and stoptech pads Just need some decent fluid. I cant wait to get these on and see if they handle an open track session.
07-11-2015, 04:49 PM | #88 |
HacKers WanTed!
Got to bring this UP if you are going for the master brake swap from the XD you need the Booster
08-03-2016, 01:48 AM | #89 |
DKDC
Drives: Yarlet Join Date: Aug 2006
Just installed the XD BBk (lol) and would highly recommend it. I did not swap for the XD MC or booster yet but plan to soon. The stock Yaris MC and booster are now the weak point and there is a slight but noticeable loss in break pressure when hitting the breaks hard (not that you ever need to in a Yaris other than to avoid an accident).
The piston diameter size difference mentioned earlier explains the slight fade in pressure perfectly. Also I had never changed my pads or rotors after 240,000 miles and over 8 years my Yaris. The OEM pads and rotors were in great shape considering their age, only a small crack on the pads and a hairline crack on one rotor.
(dick measuring info goes here) |
08-11-2017, 09:12 PM | #90 |
Drives: 08 Yaris Liftback S (RIP 07) Join Date: Apr 2007
Soo.. Wakey Wakey XD MC & BB plug n play?
"It hurts more when its wet" |
Tags |
bbk, big brake, big break kit, brakes, jdm |
Thread Tools | |
Display Modes | |
Similar Threads | ||||
07 YARIS Liftback FOR PARTS | benjomothians | DIY / Maintenance / Service | 0 | 03-28-2011 01:10 PM |
Aftermarket parts and Factory Warranty in Canada? | jonathanq | Canada | 3 | 07-11-2009 12:17 PM |
FS: C-One Parts new & used - Socal | 03Z33 | Items for Sale by private party | 90 | 06-03-2009 10:08 AM |
