Old 07-30-2013, 07:28 PM   #1
mr_miles
Drives: 2013 Yaris
I wonder if it's possible to mod the DRL box from a second gen to work on the third gen. I have a spare laying around, if CTScott could chime in I'd be more than happy to send it to you :)
Old 07-30-2013, 08:21 PM   #2
Using the 2nd gen DRL box would be more of a hassle. The simplest method is to just install a relay (with the coil power connected to the pink wire on the ignition switch connector) to provide ignition switched power to the DRLs.
If by auto off, the OP is referring to them being on with the ignition and then turning off when the headlights are turned on, a second relay would be required.
))) Tein Super Compact coilover install tips ((( aucorium DIY / Maintenance / Service 4 10-25-2011 12:42 AM
HELP needed for carputer project: Powered USB hub install Astroman In Car Entertainment + Electronics (audio / video / alarm) 15 11-01-2010 05:18 PM
Non-Yaris Audio install help needed Revsson In Car Entertainment + Electronics (audio / video / alarm) 18 08-17-2009 11:47 AM
