Old 08-27-2013, 04:06 PM   #1
sdprosser
Drives: 07 Yaris Hatch
Please Help! Replace backdoor lock assembly
Hi - I just bought a 07 Yaris hatchback and the rear lock assembly is not working. If I open the hatch it won't shut properly, therefore I can't use the hatch. Does anyone have or know of any easy step-by-step instructions for replacing this myself? The car is bare bones manual everything - I have searched everywhere and can't seem to find anything on this - even the service manual doesn't seem to make to much sense and seems to mainly deal with the power locks - any help would be super appreciated!! Please, please help! Thank you!
Scott
sdprosser is offline   Reply With Quote
Old 08-27-2013, 05:34 PM   #2
Check out this thread for my DIY on replacing it with a Scion IQ Switch. It shows exactly what you need as far as getting to it and removing it. Before you go through that though, check to make sure that the bolts that mount it to the bottom of the hatch are tight and that the two bolts that mount the hasp that it catches on are tight as well.
http://www.yarisworld.com/forums/showthread.php?t=39677
Old 08-27-2013, 05:39 PM   #3
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
Scott with problems? I'd like to introduce you to Scott with answers.
Old 08-27-2013, 06:06 PM   #4
sdprosser
LOL! Thanks guys! How hard is it to get the inside hatch panel off? The toyota dealer said it would cost me 65.00 just to take it off to see what the problem is - ugh! Thanks again for the help!
Old 08-27-2013, 06:08 PM   #5
Very easy - Just get your fingers under the bottom edge of the panel and pull. Work your way up and then lift if off at the top.
Old 08-27-2013, 06:20 PM   #6
sdprosser
Sorry for all the questions... Do the clips break easy? Thanks again!
Old 08-27-2013, 06:57 PM   #7
The hatch panel ones typically don't (unlike the front door panel ones and the interior panel ones).
Old 08-27-2013, 07:12 PM   #8
sdprosser
I'll give it a shot - Thank you!
Old 08-27-2013, 07:19 PM   #9
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
Same way with the ladies? Genius!
Thanks CTScott!
Fuel filter replacement jaimico DIY / Maintenance / Service 43 03-07-2023 12:05 PM
2009 Driver Side Headlamp Assembly kingbobby83 Items for Sale by private party 1 12-11-2010 03:10 PM
WTB: Toyota OEM Aux Stereo Jack assembly (4 pin) vitriumgts Willing to Buy by private party 0 09-25-2010 05:09 PM
LEDs to replace interior lights: Which ones? IsLNdbOi Cosmetic Modifications (Exterior/Interior) 57 04-28-2010 02:44 PM
Help: Water/Moisture Entered Fog Light Assembly bigsky2 DIY / Maintenance / Service 10 12-19-2006 01:10 AM
