Lonesome Cowboy
Drives: 2007 WHITE HATCHBACK Join Date: Feb 2007
Yuri, have you tried the search box? We have a couple of vendors here selling kits for right around 200.
SPONSORED BY
#2 | |
Be forewarned. |
so i want HID kit but i wwant to know if it will blind everyone that i cross on the road and what K i should use to have the more white possible .. i dont want purple or blue
4200k is what comes stock from every car/truck coming from the factory with HIDs.
Stay 6000k or below, and you will be getting the most usable light you can. FYI - I've never been hassled or high beamed this whole time while driving with HIDs in my Yaris LB.
#6 | |
YARIS CHICA
Drives: black 07 yaris sedan Join Date: Sep 2007
They are a great company. The owner of the company answers any questions you have, and they have good prices. And no you dont blind anyone, but some people think they are your brights, and flash at you. Hope that helps |
Gas Guzzler
FYI, on the sedan it's an 8mm nut you have to tighter/loosen in order to adjust the headlights vertically.
![]() ![]() ![]() ![]() ![]() Drives: 2007 Bayou Blue!!!!!!! Join Date: Nov 2006
After trying just to change blubs, I be afraid to install HID's, it's so tight for space. Are the instructions that come with most kits easy to follow? IS it a big job?
Still kickin around the idea of hid's. Who all has the bi beam kit and what is the brand and do they fit ok without any modding of the assembly?
Gas Guzzler
I have the hi beam kit and it fits perfectly. You just have to turn the rubber piece behind the bulb inside out to fit the larger bulb casing.
As far as installation goes... It's just as easy as changing the light bulbs only you have the added step of mounting the ballasts. |
What does everyone think of these kits on EBay??
http://cgi.ebay.com/ebaymotors/HID-B...spagenameZWDVW http://cgi.ebay.com/ebaymotors/XENON...spagenameZWDVW I know low price soooo........Has anyone had problems with the Bi beam fitting. I Imagine they would all be of correct size and not oversized. |
#12 | |
I know right?
I tested a bi-xenon kit from Xenonlink.com and it did not fit in my LB's headlight setup. The springs that hold the bulb in would not work with the HID bulb. I'm sending the kit back for a refund. I have ordered another kit from xenithxenons.com, who have tested their bi-xenon kit on Scion xBs, which also use H4 and have a similar spring retaining system so hopefully this kit should be compatible with our cars. I'll let you guys know what the results are.
-Kev 07 Bayou Blue Liftback 5-spd manual |
Did anyone ever figure out how to adjust the headlight??? Or do you just tuen that 8mm nut?
#14 |
Pop your hood.. look for a black round barrel on the inside (engine side) of the light housings, with a white + in the center.. thats your adjuster.
#15 |
Right on. I posted the comment when i was at work and in a hurry. I just checked the manual online and seen it, but for some reason I couldnt find it before. I guess I will try to lower the headlights before I give up on the HID's until someone starts selling retrofitted headlight assemblys so I dont have to mess with it. Also Chris I was curious how you have the stock assemblys and no one has flashed you. Is it in the bulb for some people like with the glare shields or de people re aim??? I just have no idea how people have HID's without retrofitting or lowering the assemblys.
#16 |
This here:
#17 |
Sedan is different. Just went outside andfound it. It looks like a light grey wheel with a 8mm nut in the middle. I just turned it clockwise and lowered my lights. Looks a 100 times better.
#18 |
![]() Drives: Toyota Yaris RS Join Date: Feb 2009
I am now returning the 8000K hid lights back to the store. After installing the lights I found out that I cannot have these lights working on my car with the DRL module. In Canada its the law to have DRL ( Daytime running lights). It would be a $360 ticket without it. So I contacted the supplier and he told me to return it. Thats $300 bucks back in my wallet!
