Old 12-28-2013, 08:32 PM   #3
SecondYaris
Drives: 2013 Yaris HB
I had the same problem when I owned my first Yaris 2007, took it to the dealer since it was still under warranty, they opened the blower box and emptied a ton of leaves stuck inside, also there was a clear rubber hose under the passenger side firewall that is suppose to drain this it, also gets plugged up. I don't think I was the first one with that problem.
The fix that I never got around to is put some sort of a screen cover over or under the windshield cowl intake, right under the wipers. I now have a 2013 Yaris, guess what it already has a screen cover under the cowl, so I hope this will prevent that problem.
SecondYaris is offline   Reply With Quote
heater, water leak
Dual 8’’ Cargo Floor Sub Box Build Ataristyle In Car Entertainment + Electronics (audio / video / alarm) 18 03-23-2016 02:27 AM
heater not working water coolant level drops Mike Hancock DIY / Maintenance / Service 4 11-03-2011 03:14 PM
heater control box issue DevilGirl DIY / Maintenance / Service 12 01-08-2010 04:45 PM
Sub Box Desgin talnlnky In Car Entertainment + Electronics (audio / video / alarm) 5 08-23-2009 02:45 AM
