Old 01-02-2014, 10:10 PM   #1
jack black
jack black's Avatar
Drives: 2007 red Yaris HB AT
Update:
I pulled the AT pan today. There was no need to replace the pan. Cosmetic damage only. I replaced the filter in the process. The filter is real, not just steel mesh that can be cleaned and reused.
The surprises:
The job was harder than I thought it would be due to low clearance and that hard plastic under engine protection that is partially in the way.
Full gallon of ATF drained. More than I expected based on reading the forum here.
The ATF, pan, and magnets were cleaner than I expected at 66,000 miles. I see that WS is the real deal and I think 100,000 miles is doable before first service.
jack black is offline   Reply With Quote
FYI VOA: Toyota ATF Type-WS craigq DIY / Maintenance / Service 10 06-24-2014 10:53 AM
ATF Drain and Fill DMZ DIY / Maintenance / Service 7 05-30-2013 11:01 PM
Replaced door panel fabric with perforated leather to match Clazzio seat covers CTScott Cosmetic Modifications (Exterior/Interior) 13 10-03-2011 11:43 PM
Water Pump being replaced... Rental Car! slothman86 DIY / Maintenance / Service 12 08-11-2010 04:14 AM
ATF TYPE IV??????????? Toy Yaris DIY / Maintenance / Service 2 01-26-2010 04:21 AM
