![]() ![]() Drives: 2008 yaris 3dr hatch Join Date: Jan 2014
replaced the SRS module. with a new one from dealer... didnt help at all... dont even know where to look for now!!!
#2 | |
Since the SRS ECU is new, and the wiring tested fine, if that is the correct code, then the pretensioner has to be the culprit. Before buying another one, you can connect a 3 ohm (make sure it is 3, not 3K ohm) in place of the pretensioner to verify.
| The Official "Bamboo the Yarisworld Traveler" Thread (v4, part 2) | Darb | Off-topic / Other Cars / Everything else Discussions | 86 | 10-18-2017 09:03 AM |
| I finally cracked the Odometer and SRS ECU code | CTScott | DIY / Maintenance / Service | 22 | 10-27-2016 02:50 AM |
| full tank | japle | Fuel Economy Forum | 15 | 12-10-2013 12:05 PM |
