Old 01-08-2014, 11:44 PM   #1
yakovenkooleg
Drives: 2008 yaris 3dr hatch
ok for the first step where i measured from one end to another on all 4 wires i was getting 00.2 ohms when my ohmmeter was set at 200
second step where i was measuring between yellow and yellow/black i was betting OL on all 4 wires. that's probably because my ohmmeter goes up only to 2M ohms.
third step where i would measure wires from seat-belt connector to the ground i was getting a 3.13 ohms on yellow wire only (for both sides) when my ohmmeter was set at 20K , but nothing for yellow/ black wire. just kept getting OL on all settings of the ohmmeter.
yakovenkooleg is offline   Reply With Quote
Old 01-09-2014, 08:36 AM   #2
OK. That is all correct. On the yellow/black to ground I see over 3 M Ohm where the yellow to ground is in the 3 K Ohm range.
Can you get your hands on two 3 ohm resistors (any wattage is fine)? I would like you to stick the 3 ohm resistor into the pretentsioner connector on both sides to see if bypassing the pretensioners makes a difference. I know you have tried multiple different pretensioners, but the resistors will give us an easy absolute test.
The Official "Bamboo the Yarisworld Traveler" Thread (v4, part 2) Darb Off-topic / Other Cars / Everything else Discussions 86 10-18-2017 08:03 AM
I finally cracked the Odometer and SRS ECU code CTScott DIY / Maintenance / Service 22 10-27-2016 01:50 AM
full tank japle Fuel Economy Forum 15 12-10-2013 11:05 AM
