Old 01-15-2014, 09:45 PM   #1
Edmond
Drives: 2007 Yarus
I got really busy with work for the last week and was unable to check the voltage at the pins until tonight. Both pins had 12v with the key in the on position. Is this a sign of a bad "body ECM" or "engine ECM"?
NOTE: I started getting 12v at pin 4a-8 after throwing 12v to it a few times trying to get it to start. Any advice with this.
Thanks again.
Edmond is offline   Reply With Quote
Old 01-15-2014, 10:51 PM   #2
Thanks again.
If 4B-9 and 4E-5 were both at +12 then the ECM was not pulling 4B-5 to ground, so I would say that the ECM is at fault. That also would explain why it still wont run when you manually power the fuel pump.
Fuel filter replacement jaimico DIY / Maintenance / Service 43 03-07-2023 12:05 PM
***The Engine Oil Bible*** Hussain-Vtec Performance Modifications 20 09-28-2016 03:47 PM
The Nitrous Thread ChinoCharles Performance Modifications 116 02-16-2016 04:07 PM
Car shuts off when A/C turned on... Howster DIY / Maintenance / Service 33 07-06-2013 06:00 PM
