![]() ![]() Drives: 2008 Hatch Red Join Date: Apr 2012
If your car is not lowered you may be able to slide under and do it with the car sitting on the ground. This is how I do mine without any jacks involved.
Same here.
![]() ![]() Drives: 2007 Toyota Yaris Sedan Join Date: Oct 2012
I have a 2007 sedan and I slide under and do it without jacking the car up as well.
Roy |
haha, i hate how i have to reach the oil filter when the car is not jacked up.
Anyways, CTScott should tell us how much torque to apply to the drain plug bolt. It shouldn't be tighten to the point where you can't take it off with a single socket. |
28 ft lb is the torque for the drain bolt. If you don't have a torque wrench it is basically snug without killing it.
![]() ![]() Drives: 07 Yaris Join Date: Sep 2012
Anyone ever used a Fumoto valve? When I had my WRX a bunch of the Subaru guys were using them but I never really asked. Seems like something that would make life a lot easier..?
http://www.qwikvalve.com |
#7 | |
#8 | |
![]() ![]() ![]() Drives: 2007 Toyota Yaris Hatchback Join Date: Sep 2012
Blue beast
Hi use car ramps no need to jack up and down, much safer too
#10 | |
![]() ![]() ![]() ![]() Drives: 3-door hatch Join Date: Oct 2010
I made my own ramp, though. It a triple layer of 2X12s bolted together in a ramp shape. Commercially availabe ramps are too high. |
drain plug
If you have to use an extra pipe or breaker bar to remove an oil drain plug that's suppose to be only 25-28 fb's than something's wrong. Hate to tell ya but the previous owner probably stripped the threads and instead of replacing the oil pan just JB WELD or glued the plug to the oil pan some how. I just put mine at around 20-25 ftb's to be on the safe side of not stripping. The oil pan is only 40-50 bucks on the internet and a fairly easy job anyhow. good luck to ya
toyota
lol i change my oil without jacking the car and thats sitting on eibach springs.
If my calculations are correct, when this baby hits eighty-eight miles per hour... you're gonna see some serious shit!!!!!! "Horsepower is how fast you hit the object. Torque is how far you move that object.." |
| Oil Change Question... | jayeh | DIY / Maintenance / Service | 4 | 03-05-2012 11:15 PM |
| Is it safe to change from synthetic oil to regular oil | hero | General Yaris / Vitz Discussion | 18 | 02-21-2010 10:51 PM |
| $86.44 for oil change? I feel screwed | behour | General Yaris / Vitz Discussion | 98 | 01-04-2010 07:10 PM |
| Super Amazing Oil Change DIY | id3379 | DIY / Maintenance / Service | 34 | 11-28-2008 01:20 PM |
| Oil change question | Ryu | DIY / Maintenance / Service | 22 | 03-07-2006 11:21 PM |
