#19 |
![]() ![]() Drives: 2009 Yaris HB Join Date: Sep 2013
.....and the winner IS !!!!
16 inch MOMO RIMS
#20 |
Toyota Echo NOOB!
Drives: 2005 4dr Echo hatchback Join Date: Oct 2013
post up a pic of the car
2005 Echo hatchback Project (Silver) Instagram: Lawrencephotography |
#21 |
here it is! We fit them to make sure the bolt pattern worked. Noticed the lug nuts are small on the stock rims and sink deep into the new rim lug holes. Do I HAVE to buy new longer lug nuts? |
#22 |
5 lug hubcaps
That one Momo appears to be in pristine condition. Are the other 3 equally as nice?
#23 | |
Yes they were all in really good condition.bit 2 hav3 crub rash. Im going to plasti dip them black. So do I need longer lug nuts? Also what size threads are they on the yaris? |
#24 |
12x1.5. I would get this since the hole seems to be tight fit.
#25 |
#26 |
Pics please with wheels on the car...nice rims :)
#27 |
![]() ![]() Drives: 07 Yaris Join Date: Sep 2012
Those will look nice on the white car!
#28 |
Toyota Echo NOOB!
Vancouver local
#29 |
The depth of the wheel's lug nut holes doesn't matter. The key is to look at the shape of the surface that the lug nut touches and make sure that it is the same shape as the lug. So, if it has a taper (and the angle of the tapers match), you would use tapered lugnuts (which is what the OEM ones for the steelies are). Some alloy rims have really tight holes, where you can't fit the stock lugs with a wrench into. In that case you have to use smaller outer dimension lugs.
| I NEED Boost... Opinions puh-lease | Focus_Sh1ft | Forced Induction Forum | 551 | 02-08-2013 06:55 PM |
| Sway bar opinions | Nelson | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 24 | 12-10-2008 07:40 PM |
| Want opinions automatic vs. manual transmission | anik | New YARIS Purchase Forum | 84 | 07-10-2007 05:25 PM |
| Need Opinions on Package Options | bdc87 | New YARIS Purchase Forum | 8 | 06-26-2007 02:55 PM |
| Opinions on '07 Hyundai Accent hatch? | Yaris Revenge | Off-topic / Other Cars / Everything else Discussions | 44 | 05-08-2007 12:18 AM |
