![]() Drives: Toyota Echo Join Date: Feb 2014
My goal is to find out how necessary a return fuel line is for turbo application on a 1nz-fe..
#2 | |
So, the question is how much boost are you intending? If you are going to stay in the 8 psi range, then you don't need to upgrade the fuse pump, but if you are going to go above about 12psi, then you will start to run into the limits of the stock pump.
#3 | |
I'm in the process of pulling down the block, and forged pistons and rods will be installed, ideally looking at 12-15 PSI for a daily driver. |
| DIY - Removing the gas tank from under the car (to access the fuel filter, etc.) | CTScott | DIY / Maintenance / Service | 1 | 08-21-2013 03:57 PM |
| Yaris Fuel Pump | HTM Yaris | General Yaris / Vitz Discussion | 12 | 03-22-2012 03:34 AM |
| The "let's brainstorm how to make a piggyback work" thread | eTiMaGo | Forced Induction Forum | 83 | 08-17-2011 03:54 PM |
| Any body have good data on the Yaris fuel system? | LtNoogie | Performance Modifications | 9 | 03-26-2009 08:01 AM |
| Low fuel light | falkor_99 | General Yaris / Vitz Discussion | 35 | 08-24-2007 03:20 PM |
