Old 03-03-2014, 10:00 PM   #1
spiceyhotwings
Drives: 2009 Yaris RS 5 door
Would the high beam system stop working if even just 1 filament is burned out?
Do you know which fuse runs the H/L headlights?
my new 2009 Yaris RS 5 door
spiceyhotwings is offline   Reply With Quote
Old 03-03-2014, 10:37 PM   #2
Both side high beam filaments would have to be burned out for both side high beams to be not working.
The H-LP RH and H-LP LH fuses feed the right and left sides respectively.
Low Beams not working Karri'es Yaris DIY / Maintenance / Service 7 02-10-2012 08:34 PM
Problem with low beams and High Beams thebarbrr DIY / Maintenance / Service 7 09-22-2010 08:43 AM
Yaris sedan low and high beam jorizk DIY / Maintenance / Service 10 03-02-2010 09:49 AM
DIY - HID Retrofit Violin DIY / Maintenance / Service 57 06-11-2007 06:17 PM
