Old 05-15-2014, 11:34 AM   #1
mpcv2000
mpcv2000's Avatar
Drives: 2004 Echo HB Hatchback 2 Door
Originally Posted by Ryze268 View Post
In the .pdf it says the tach signal comes from the Black wire on the C13 connector, is this true?
I'll answer that if you don't mind.
C13 ( Black ) is the tach signal and to get my 05 Tach to work in my 04 I took the signal on the OBDII port that is also the black wire and hooked it up to the Black wire on the C13 connector.
This is a very easy swap if you take your time.
mpcv2000 is offline   Reply With Quote
Old 05-15-2014, 12:00 PM   #2
Ryze268
Ryze268's Avatar
Drives: 2002 JDM Vitz 1.3
That's what I'm confused about, my cluster didn't come with a tach gauge but I'm seeing the black wire in my C13 connector.
Can I pick up the tach signal from that wire? My Vitz is JDM so it doesn't have an OBDII port
2000 JDM Vitz [2NZ-FE Crap-otmatic] < Now Manual Conversion complete
Follow me on Instagram:
instagram.com/itzkingjustin
Ryze268 is offline   Reply With Quote
Old 05-15-2014, 12:11 PM   #3
You should be able to use that wire for your tach. The pin on the OBD connector where that wire goes to for US and Canadian cars is an unused pin for OBDII communications. Toyota just happens to bring the pulsed tach signal to that pin.
Old 05-15-2014, 12:08 PM   #4
mpcv2000
mpcv2000's Avatar
OBDII is not a universal thing ?
I'll let other people respond than because I'm not the best when comes electricity and diagrams .
Old 05-15-2014, 12:13 PM   #5
mpcv2000
mpcv2000's Avatar
You should change your name for WikiScott
Old 05-15-2014, 12:19 PM   #6
Ryze268
Ryze268's Avatar
Awesome! I'll give it a try and let you guys know how it turns out :)
Old 11-22-2014, 11:54 AM   #7
theguy
Drives: toyota echo
hello guys... sorry but my english is too bad ... i want to know if you know who have echo rs cluster for sale i very interesting for 1 ty ...
theguy is offline   Reply With Quote
Old 02-07-2016, 12:54 AM   #8
lambornisyoantuan
Drives: 2000 Yaris
I'm also doing a cluster swap from a 2000 Vitz, my stock gauge has no rpm(manual transmission). And i bought a vitz gauge with rpm(automatic transmission). Considering that mpcv2000 and I have the same problem, but the year model of our car is different, also the sockets and wire colors. I hope CTScott can address my problem
lambornisyoantuan is offline   Reply With Quote
Old 02-07-2016, 07:46 AM   #9
The Vitz has wiring differences from the USDM Echo. You will need to track down the wiring diagrams for your car and for the one which the cluster came from.
Old 02-07-2016, 09:41 AM   #10
lambornisyoantuan
Drives: 2000 Yaris
[IMG][/IMG]
22pin ^
18pin ^
stock pin (upper part gauge) ^
stock pin (lower part gauge) ^
actually, its a toyota Echo here in the Philippines.
Old 07-18-2016, 11:32 AM   #11
lambornisyoantuan
Drives: 2000 Yaris
I've successfully changed my cluster. Toyota Echo here in the Philippines was built in Japan, just sayin'
so my problem is i dont know where to tap the "hot" and cold" wires from my RS gauge to the stock wiring harness. I hope you can help me CTScott highly appreciated
Old 12-06-2016, 06:18 AM   #12
engineer6
Drives: Vitz 2001
Cluster swapping with RPM
Hey Dear,
I also tried changing my old meter (without RPM) with the one having RPM Needle. I followed the same PIN Diagram and things. Thanks God, Every thing is working properly after the swap except for speedometer.
In fact, the new speedometer is showing a delayed speed. Like for testing I turned on the GPS in android and matched with the speedometer and the speedometer reading is 10 km/hr delayed.
For example, meter is showing speed of 40 km/hr while in actuality the speed is 50 KM/HR.
Please help me with this one
engineer6 is offline   Reply With Quote
Old 12-06-2016, 10:12 AM   #13
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
Originally Posted by engineer6 View Post
Hey Dear,
You might have a different speed sensor ratio in the transmission that the car the cluster came from.
Old 12-09-2016, 09:58 AM   #14
engineer6
Drives: Vitz 2001
Thanks for replying. So is there anything I can do about the sensor? I mean can I make any adjustment or I have to buy another speed sensor that is completely synchronised with the new meter?
I was also thinking about resetting the ECU. Would that help?
Old 09-05-2018, 01:36 AM   #15
lambornisyoantuan
Drives: 2000 Yaris
After a long time, i have finally tap my HOT and COLD temperature on my Gauge. there are few switching needed for it to work!
Old 12-09-2016, 10:05 AM   #16
Bluevitz-rs
If it is the case, there's nothing you can do other than completely tear apart the transmission and change the gear on the diff to match the ratio of the other transmission and speed sensor.
The speed signal goes directly from the sensor in the transmission to the cluster and then to the ecu. Resetting the ECU won't do anything. Be sure you don't have a bad connection from your wire changeover. Resistance in the signal wire could be the cause of the low speed indication.
Old 12-09-2016, 10:38 AM   #17
engineer6
Drives: Vitz 2001
.YouR point regarding different ratio is plausible as I have tried different meters with the dealer and all had the same issue.
But still to be on safe side, I will check for cold joints causing attenuation in speed signal.
Post Script: for other people information, I am driving Toyota Vitz 2001(not echo or Yaris) imported directly from Japan.
Old 02-15-2018, 12:51 AM   #18
loud41
Drives: 2001 Echo
I know this is an old post, but I wanted to complete the work that was started here and finish the wiring diagram for this cluster swap for the hi/low beams problem. After looking at the two diagrams, I'm fairly certain how to get the hi/low beam LED to work on the cluster. The '05 cluster gleans power directly from the headlights in order to power the LED, whereas the '04 cluster has a splice from the main power block that runs the cluster in order to power the light bulb. The connection to the headlight switch merely connects the hi/low beam lamp circuit to ground allowing either the LED or the lightbulb to illuminate when the switch is flipped on.
So my theory is this:
Splice a wire from the '04 connector, C14 pin 1(L-Y), to the '05 connector, C14 pin 22(R-L). This should connect the LED to the 12v power source that runs the entire cluster and should power the LED when you flip on your hi beams.
I can confirm this shortly after I complete my own swap this weekend.
loud41 is offline   Reply With Quote
Yaris Liftback cluster w/tach for SALE!! jose3sgte Items for Sale by private party 5 11-13-2013 10:35 AM
Willing to trade 2010 MPH liftback cluster w/tach w/ABS for cluster w/tach wo/ABS Jabro Willing to Buy by private party 4 12-21-2012 06:34 PM
Lower control arm replacement 2005 Echo ? Infinitrium Wheels, Tires and Suspension Forum sponsored by The Tire Rack 1 06-27-2012 03:23 PM
2007 Yaris Sedan cluster, with Tachometer. (Won't fit Liftback) H3LlIoN Items for Sale by private party 3 09-18-2011 03:55 AM
