Old 05-01-2014, 06:17 PM   #1
Originally Posted by Ryze268 View Post
Basically, the 1NZ ECU from the XB won't work?
No. It would need to be from another 2NZ vehicle, if you swapped the tranny, but kept your same 2NZ engine. All 1NZs are single cam, and their ECMs lack the input for the 2nd cam sensor and output to drive the 2nd oil control valve.
Old 05-01-2014, 07:50 PM   #2
Ryze268
Ryze268's Avatar
Drives: 2002 JDM Vitz 1.3
Wow, thanks for the info. I thought they were they same engine just a different stroke. Where can I read up more about these engines?
2000 JDM Vitz [2NZ-FE Crap-otmatic] < Now Manual Conversion complete
Follow me on Instagram:
instagram.com/itzkingjustin
Ryze268 is offline   Reply With Quote
Old 05-01-2014, 08:38 PM   #3
Actually, I must be smoking crack tonight. The 1NZ and 2NZ are basically the same. I was thinking of the 1NR-FE, which is dual VVTI.
So, back to your original question - Your fuel maps would be a bit rich with a 1NZ ECM, but other than that it should be OK. Can you post a picture of the ECM connectors on your Vitz ECM?
Old 05-01-2014, 09:28 PM   #4
Ryze268
Ryze268's Avatar
lol we all have our moments.
Running rich won't be bad as long as I can get rid of the check engine light. I ordered a bigger throttle body, hopefully it fits.
Next up are bigger injectors and an adjustable fuel pressure regulator.
I plan to dabble in a bit of forced induction soon. I'll see if I can get that pic for you in the morning.
Thanks
-Justin
Tags
ecu, manual, swap
Need Help with 2NZ ECU pinout Aleil DIY / Maintenance / Service 3 12-28-2020 09:40 AM
I finally cracked the Odometer and SRS ECU code CTScott DIY / Maintenance / Service 22 10-27-2016 01:50 AM
standalone and stock ecu Radou Performance Modifications 0 06-16-2013 04:47 PM
Yaris ECU broken??!!!!!! phb10186 General Yaris / Vitz Discussion 30 05-26-2010 09:56 AM
Tricking the ECU to Relearn AF map gwasabi Performance Modifications 126 05-16-2009 06:15 PM
