Old 05-01-2014, 10:28 PM   #8
Ryze268
Ryze268's Avatar
Drives: 2002 JDM Vitz 1.3
Actually, I must be smoking crack tonight. The 1NZ and 2NZ are basically the same. I was thinking of the 1NR-FE, which is dual VVTI.
So, back to your original question - Your fuel maps would be a bit rich with a 1NZ ECM, but other than that it should be OK. Can you post a picture of the ECM connectors on your Vitz ECM?
lol we all have our moments.
Running rich won't be bad as long as I can get rid of the check engine light. I ordered a bigger throttle body, hopefully it fits.
Next up are bigger injectors and an adjustable fuel pressure regulator.
I plan to dabble in a bit of forced induction soon. I'll see if I can get that pic for you in the morning.
Thanks
-Justin
2000 JDM Vitz [2NZ-FE Crap-otmatic] < Now Manual Conversion complete
Follow me on Instagram:
instagram.com/itzkingjustin
Ryze268 is offline   Reply With Quote
ecu, manual, swap
Need Help with 2NZ ECU pinout Aleil DIY / Maintenance / Service 3 12-28-2020 10:40 AM
I finally cracked the Odometer and SRS ECU code CTScott DIY / Maintenance / Service 22 10-27-2016 02:50 AM
standalone and stock ecu Radou Performance Modifications 0 06-16-2013 05:47 PM
Yaris ECU broken??!!!!!! phb10186 General Yaris / Vitz Discussion 30 05-26-2010 10:56 AM
Tricking the ECU to Relearn AF map gwasabi Performance Modifications 126 05-16-2009 07:15 PM
