#1 | |
![]() ![]() Drives: 2004 Echo HB Hatchback 2 Door Join Date: Oct 2013
C13 ( Black ) is the tach signal and to get my 05 Tach to work in my 04 I took the signal on the OBDII port that is also the black wire and hooked it up to the Black wire on the C13 connector. This is a very easy swap if you take your time. |
#2 | |
![]() ![]() ![]() Drives: 2002 JDM Vitz 1.3 Join Date: Feb 2013
Can I pick up the tach signal from that wire? My Vitz is JDM so it doesn't have an OBDII port
2000 JDM Vitz [2NZ-FE Crap-otmatic] < Now Manual Conversion complete Follow me on Instagram: instagram.com/itzkingjustin |
You should be able to use that wire for your tach. The pin on the OBD connector where that wire goes to for US and Canadian cars is an unused pin for OBDII communications. Toyota just happens to bring the pulsed tach signal to that pin.
| Yaris Liftback cluster w/tach for SALE!! | jose3sgte | Items for Sale by private party | 5 | 11-13-2013 10:35 AM |
| Willing to trade 2010 MPH liftback cluster w/tach w/ABS for cluster w/tach wo/ABS | Jabro | Willing to Buy by private party | 4 | 12-21-2012 06:34 PM |
| Lower control arm replacement 2005 Echo ? | Infinitrium | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 1 | 06-27-2012 03:23 PM |
| 2007 Yaris Sedan cluster, with Tachometer. (Won't fit Liftback) | H3LlIoN | Items for Sale by private party | 3 | 09-18-2011 03:55 AM |
