Old 05-27-2014, 06:53 PM   #1
NEexpat
Drives: 2009, auto, 4dr LB
My Fiamm El Grande install
Just completed my Fiamm install. Wow, maybe because I'm used to the "meep meep" these are loud and well worth the $20 + change cost from Amazon.
Chose these over others because it is my understanding they draw less than 10 amps, so while there is a relay included, the less wiring, splicing, cutting, T-tapping I'm involved with the better. So I opted out of the relay. Others, don't take my advice, you do so at your own risk.
Several days ago I was hoping to ID the part number # for the female F connector on a Toyota premium horn install harness. I wanted that part to make my own harness. Well on my cyber travels I could plainly see that a lot of the "meep meep" horns, the flat round Denso's have that clip or one like it riveted to the back horn.
I went to the Pick and Pull got a horn off a Corolla drilled out the rivet got the clip home, dremeled off the plastic around the connector made my own harness and sealed it with some liquid tape.
I decided to just remove the bumper cover as well as the black, spacer clipped above the radiator, there is a threaded hole to left of the horn bolt that I used for the second horn
Anyway, quite simple really, the hardest part is taking off the cover and replacing it. I painted the brackets flat black, taped off both ends though, the bracket acts as the ground on these setups so that metal on metal has to be a good clean surface contact.
I liked the little grills over the mouth of the horns. I just didn't care for them being shiny silver, so removed them and painted them black as well.
Thanks again Yarisworld!
Cheers.
NEexpat is offline   Reply With Quote
))) Tein Super Compact coilover install tips ((( aucorium DIY / Maintenance / Service 4 10-25-2011 12:42 AM
HELP needed for carputer project: Powered USB hub install Astroman In Car Entertainment + Electronics (audio / video / alarm) 15 11-01-2010 05:18 PM
fiamm el grande horns installed staypuft Cosmetic Modifications (Exterior/Interior) 14 08-22-2010 08:29 PM
