Old 07-31-2014, 07:10 AM   #1
268i
Drives: 06' Yaris 1.3l
Hand tight = WRONG. Look on the filter. It says tighten the filter until it makes contact with the engine block. Then turn it another 1/2 turn. Or 3/4 turn or whatever depending on the car.
What you dont want to do it turn it more than that figureing if that is good more is better! Then it will be difficult to remove.
I use ramps to change my oil. While Im under there I inspect the car for dammage, leaks, and also the condition of the CV joint boots (not really necessary any more until over 100k miles)
Could it be possible that having it too tight could also cause a leak? I've heard about those stories with oil filter leaks/falling off and they scare the crap out of me. I'll try the 3/4 turn after contact w/ engine block. Thats what it said on the filter box but i've read so many different opinions on how tight oil filter should be.
Hmmm... never seemed to have a problem removing filter. (I have one of those cap-on wrench style removal tools - Works very well) I usually do an oil change every 5-8 thousand miles. I alternate between DIY oil change and a full service at the mechanics to make sure I ain't missing out on checking anything.
I've been wanting to invest in ramps. They're around $100 per set but doubt they'd fit the yaris since no one in this country sells low profile ramps and ain't nobody got time to make their own ramps out of wood.
268i is offline   Reply With Quote
Old 07-31-2014, 08:51 AM   #2
bronsin
bronsin's Avatar
No too tight wont leak unless you strip the threads!
To prevent leaks make sure the rubber gasket is on the oil filter you removed. Once in a while the rubber gasket sticks to the block. Putting an oil filter on top of a stuck gasket is a sure way to have a severe oil leak.
Look on Clist for ramps for less than $100. I use the old ramps Ive had for years. Just shove the fender out of the way.
Old 07-31-2014, 08:58 AM   #3
bronsin
bronsin's Avatar
Theres your problem right there!
Do what the box says NOT what others say!
Yaris Oil Change DIY rningonfumes DIY / Maintenance / Service 91 01-11-2019 07:18 PM
***The Engine Oil Bible*** Hussain-Vtec Performance Modifications 20 09-28-2016 02:47 PM
A Mystery Oi'll Say! Yar Is Word Fuel Economy Forum 16 05-11-2013 04:22 AM
Motor oil debate - interesting info but a long read. mikeukrainetz General Yaris / Vitz Discussion 6 12-10-2006 08:16 PM
