Old 09-11-2014, 06:46 PM   #1
brg88tx
Drives: 07 Yaris Sedan, Auto
I've had mine on cruise at 82 mph for 5 hours straight several times with no problem.
brg88tx is offline   Reply With Quote
Old 09-11-2014, 07:18 PM   #2
428CobraJet
Drives: '09 Yaris 3dr, 13 F150rcsb 5.0
Brg...what kind of mpg were you knocking down?
You are what you drive.
428CobraJet is offline   Reply With Quote
Old 09-11-2014, 07:20 PM   #3
nobodywise
nobodywise's Avatar
Drives: Yaris sedan
Mine sounds like it's crying at those speeds too, glad I'm not the only one, then again... I drive a sedan
nobodywise is offline   Reply With Quote
Old 09-15-2014, 09:49 PM   #4
SpeedyYaris
SpeedyYaris's Avatar
Drives: 2009 3door 5-speed Manual
after driving 85-90 i ended up getting 33mpg.. Pretty good if you ask me XD But i was only one in the car and ac was off but still :)
SpeedyYaris is offline   Reply With Quote
Old 09-15-2014, 11:17 PM   #5
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
Can't complain about that man. Ask some of these other folks driving other whips and they will envy you getting that type of FE at consistent speeds over 80.
Old 09-22-2014, 12:02 PM   #6
600RRgoal
Drives: Yaris
I just came back from a trip.. 18 hours cruising roughly 75 the entire way to destination, and 14.5 hours cruising roughly 75-80 back. No problems and I got over 39 mpg both ways. No stops for anything other than gas
600RRgoal is offline   Reply With Quote
Old 09-22-2014, 12:22 PM   #7
428CobraJet
I dont get that good. Maybe its the ethanol. ..or lack of cruise control.
Old 09-22-2014, 12:30 PM   #8
600RRgoal
Drives: Yaris
Cruise was a savior for sure! My best tank was just under 44 mpg.
Old 01-16-2015, 01:36 AM   #9
El Kapitan
Senior Veteran
Drives: 2007 5 door hatchback
lol, this is why i'm always so scared when i buy used cars... but at least you guys take good care of them. a person who drives slower but skips service intervals is worse of course.
El Kapitan is offline   Reply With Quote
Old 01-16-2015, 03:58 AM   #10
IllusionX
Drives: 07 Yaris Sedan Aero
I took mine (toyota Echo) all the way to 113mph before. I even followed a Mitsubishi Eclipse at 100mph on my way to NYC.
Old 01-16-2015, 06:05 AM   #11
colj00
DIYer
Drives: yaris 1.5 MT
you will not damage the engine at 4000 rpm, they designed it so it can be run at long periods safely at any rpm below the redline. you do far more engine damage driving your car when you first start it up in the morning.
colj00 is offline   Reply With Quote
Old 01-19-2015, 11:45 PM   #12
Echo86
Drives: 2003 Toyota Echo
Only concern at high speed is a strong crosswind. MPG at a buck 20 avg 43 in the winter. Just shy of 50 in the summer.
Echo86 is offline   Reply With Quote
Old 01-20-2015, 08:14 AM   #13
IllusionX
Question about HIGH Speeds
When I had my echo, it was more stable at 120kmh than it is at 80kmh with very strong crosswinds. Strong enough to flip 18 wheelers...
I was also lowered with eibach ProKits.
Old 01-23-2015, 12:56 AM   #14
Echo86
[QUOTE=IllusionX;753933]When I had my echo, it was more stable at 120kmh than it is at 80kmh with very strong crosswinds. Strong enough to flip 18 wheelers...
I meant high high speeds. The ones where your check engine light comes on because the car doesn't recognize WARP on the speedometer.
Tags
high speed, highway, toyota yaris
Voltage regulator and Amperage question... cr.chango DIY / Maintenance / Service 13 11-24-2009 01:59 PM
ctrl-alt-delete question & free anti-virus question Shroomster Off-topic / Other Cars / Everything else Discussions 18 09-08-2009 04:57 AM
Retrofit Question ChinoCharles Cosmetic Modifications (Exterior/Interior) 19 05-13-2009 07:20 PM
Amplifier Watt Question....noob question hasher22 In Car Entertainment + Electronics (audio / video / alarm) 4 09-27-2007 04:59 PM
catalytic converter question SamDaYarisMan Performance Modifications 14 09-08-2006 11:18 AM
