![]() Drives: 2012 se Join Date: Sep 2014
Thanks CTScott. The instrument panel was a really easy remove.. just pulled the trim gently and slowly, removed the 2 screws, then tilted it out.
I got a reading of 0 ohms with gauge stuck on the full mark before taking the reading. 117 miles on tank, so clearly the sender is not giving the resistance within the 13.5 to 414 ohms. 117 miles is roughly 3.4ish gallons from full. It makes sense that 0 ohms would peg the needle to full mark if less ohms is full and more ohms is empty. I am going to take another reading after the gauge needle moves and sticks again. It would be nice to have an actual number correlation to the gauge needle being anywhere between the full and empty marks.... but based on this I think I am pretty certain the sender is bad. |
#2 | |
![]() Drives: Yaris P1 1l 2000 Join Date: Sep 2014
Dear CTScott,
as I have found several posts concerning fuel pump problems, where you provided help: can you probably give me a hint how to get the pump out of a Yaris mk1 from 2000? My problem is shown in this thread: http://www.yarisworld.com/forums/showthread.php?t=52565 Best regards, Johannes |
| Tags |
| fuel, fuel gauge, gas, gauge, sedan |
| Miles per tank | joeharth | Fuel Economy Forum | 61 | 07-08-2010 08:37 PM |
| Launching @ 4Krpm problem .... need tips | Parmas | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 12 | 12-30-2009 09:11 PM |
| The last gas question | Tonavi | DIY / Maintenance / Service | 56 | 04-27-2009 09:40 PM |
| Low fuel light | falkor_99 | General Yaris / Vitz Discussion | 35 | 08-24-2007 04:20 PM |
| Fuel / Temp / Mileage Gauge - Special LED Readings? | bigsky2 | General Yaris / Vitz Discussion | 3 | 05-31-2006 10:04 AM |
