Old 09-13-2014, 07:46 PM   #1
CB900F2
Drives: 08 Sedan
Hey guys..
Thank you for your feedback, and I changed out the gasket and it was much easier then I was expecting..
No need for heat on the bolts, one pull with my 18" long racket, and they broke lose.
And for my sedan, I needed to unhook the middle hangers as suggested by Wolfman, as if you don't, there isn't enough room to work at getting the gasket off, and re-installing the new one.
And in my situation, I had this issue when I would be braking where at from the 60km to the 50km speed, I would get a rumble with in the car. I was really thinking I had warpped rotors, and it was related to the gasket.. I can only assume the gasket was also leaking and it would somehow cause something to resonate enough to cause this rubble/shake through out the car.
Thanks again guys.
Originally Posted by Exiwolfman View Post
Yup enuf space just have to unhook the exhaust from middle hangers at least one side so u can flex it back .
sent from my S4 on Mars
Tags
engine bay, exhaust, noise while moving, noises, rattling
Toyota's new subcompact will use Mazda's Skyactiv engine Kal-El Off-topic / Other Cars / Everything else Discussions 43 03-25-2014 02:01 AM
excessive valve and or engine noise? thomasward00 General Yaris / Vitz Discussion 3 06-07-2007 01:34 PM
anyone use Dynamat/ Be Quiet to deaden exhaust noise? Galavoxx Performance Modifications 9 11-29-2006 05:28 AM
engine noise?? poshi General Yaris / Vitz Discussion 23 09-04-2006 11:45 PM
