Old 09-16-2014, 04:46 PM   #1
blackace4
Drives: 2007 Yaris
Fuse is good. Replaced the Ignition Switch. Everything works except the Electronic steering and the airbag. Also the car idles at 300 rpm and I had set it at 800 when I last changed plugs.
Never mind on the EPS. I put the 50A fuse back in the wrong spot. The airbag light is still on though.
blackace4 is offline   Reply With Quote
Old 09-16-2014, 09:15 PM   #2
For the idle, if you adjusted it without disconnecting the battery in between adjustments, that is likely the cause. The throttle control system on the Yaris is not setup for dynamic tweaking of the idle screw.
Check out this thread for instructions on how to see why the airbag is not happy:
http://www.yarisworld.com/forums/sho...d=1#post557473
Steering Wheel question heeroyuy01195 Cosmetic Modifications (Exterior/Interior) 33 03-07-2012 01:27 AM
Mesh Steering Wheel Cover... Toxic? IsLNdbOi Cosmetic Modifications (Exterior/Interior) 20 07-03-2010 05:53 AM
SCION SPORT STEERING WHEEL, RED, XA AND XB, 03 TO 06 justoneyaris Items for Sale by private party 3 12-04-2008 06:30 PM
steering wheel setup aucorium Cosmetic Modifications (Exterior/Interior) 0 07-24-2007 01:05 AM
