Old 09-27-2014, 11:37 AM   #1
thekatiel
Drives: 2010 toyota yaris
Rounded bolt replacing belt
Need some assistance.
Thought I could manage to replace my serpentine belt on my own but ended up rounding off the 12mm bolt. I went to Lowe's to see if I could get a replacement bolt for when I did get the rounded bolt off but they said I would need to know the size of the rest of the bolt. All I knew was that I used a 12mm wrench (and a non hexagon socket thing).
Does anyone know the exact size of the bolt? And the easiest way to get off the rounded bolt?
thekatiel is offline   Reply With Quote
yaris timing belt phenoyz General Yaris / Vitz Discussion 16 02-24-2015 01:05 AM
Squeal from Engine after replacing Water Pump and Serpentine Belt vidfan DIY / Maintenance / Service 7 06-24-2014 10:41 AM
Is every 24,000 miles correct for replacing serp belt? JerseyJeff84 DIY / Maintenance / Service 11 09-09-2011 06:35 AM
Need help replacing acessory drive belt!!! stevebo DIY / Maintenance / Service 13 04-07-2011 02:57 PM
