Old 11-07-2014, 05:59 PM   #1
Ben_
Drives: 2010 Yaris Hatch
Imaginary STF build
Hey guys,
I don't have money to spend on lots of expensive parts plus next season for Utah region SCCA doesn't begin till next March, but I still love writing up potential builds. Here is one for the STF class, which has a pax of 0.801 compared to the HS pax of 0.797. Not a huge difference for the MUCH greater possibility to maximize the performance of our little cars! This build has parts with bang for buck and performance in mind.
So beginning from the ground up, since that is the best way to build a car for auto-x IMO.
http://www.tirerack.com/tires/tires....R5GFR&i1_Qty=4
225-45-15 BFG Rivals maximizing the tire width limit of STF, maximizing the UTQG limit of 200 for 2015, and keeping a small diameter for gearing benefits
http://www.tirerack.com/wheels/Wheel...&association=2
Advanti Storm S1 15x7 e35 which is the exact width to match the tires also is within width limits of STF and is more budget oriented than Enkei RPF1 but is only 1 pound heavier per rim
All of the following are available on Micro Image
R1 concepts drilled and slotted rotors with carbotech track pads, SS brake lines and custom venting from the fog light holes or lower bumper grill rear brakes must remain drums to keep the factory parking brake
Whiteline 23mm rear antiroll bar, Megan Coilovers
micro image intake manifold, 1.8L TB, AFE 1.8L intake, remove plastic engine cover
Megan Header, custom 2.25" straight pipe with high flow cat
APEXI AFC-neo piggyback tuner
DENSO spark plugs, MI lightweight crank pulley, K&N oil filter
Micro Image shifter cage bushings, MI shifter cable bushings, MI short shift kit
Total Cost = 4586.94 + shipping + tuning + exhaust fab
Ben_ is offline   Reply With Quote
1NZ-FE All Motor Build burned Performance Modifications 19 10-24-2014 11:56 AM
Carbon build up in the throttle body Sedan DIY / Maintenance / Service 18 11-16-2013 12:44 AM
fnkngrv's custom trailer build log fnkngrv Off-topic / Other Cars / Everything else Discussions 5 10-12-2012 02:24 PM
Build Your Yaris, toyota.com artyin General Yaris / Vitz Discussion 3 05-03-2006 05:52 PM
