Old 11-14-2014, 01:19 PM   #1
vicky
Drives: Yaris 2010
I just replied, but can't find my post. Trying again.
@CTScott
Thank you for your very helpful reply.
For Toyota Techstream, do I have to go to the dealer? Or is it downloadable somewhere? If it is easy enough, I can give it a shot.
I also found a couple of posts with replies from you to similar issues.
http://www.yarisworld.com/forums/showthread.php?t=29721
http://www.yarisworld.com/forums/showthread.php?t=29472
Thank you for your detailed replies. I have a couple of questions.
Am I correct in assuming that the keyless remote door unlock and the engine immobilizer are independent of each other? If I do the door unlock procedure, it shouldn't affect the immobilizer (and viceversa)?
I seem to have one of the master keys, so I should be able to do both. The keyless remote door unlock seems less scary :-). If something wrong happens, I should be able to open the door manually, correct?
vicky is offline   Reply With Quote
Tags
key remote, lost key
Question about adding another key and fob rcvmini DIY / Maintenance / Service 19 10-14-2018 10:17 PM
Transponder key programming teddy DIY / Maintenance / Service 6 04-28-2015 07:32 PM
Lost key (transponder and remote lock/unlock) shyeoh DIY / Maintenance / Service 4 07-11-2013 06:04 AM
I lost my master keyless entry key, need suggestions.... Frankd1 DIY / Maintenance / Service 19 12-02-2010 12:13 AM
Lost spare key !!!!!! mata5346 General Yaris / Vitz Discussion 24 09-21-2009 01:40 PM
