![]() ![]() Drives: 2012 Yaris 5dr Hatch Join Date: Oct 2014
Fuel efficiency mods
I am currently averaging around 30mpg in the city with my 2012 se and managed 45mpg on the highway
Since this car will never be fast I want to mod it for mpg Here are my ideas, feel free to comment.
Only Happy When it Rains
Those are good ideas.
Also think about lowering it too, the lower the car, the less air gets under it. Lightweight wheels, pulleys, and flywheel will also help gas mileage. Get a short ram intake before you get an exhaust. I have a K&N and it helped get a couple mpg's as long as it is not freezing out. Blocking off all of the intakes/etc in the front as well as an air damn will help, just make some of them easily removable so you can adjust for hot days. A good place to look for other ideas is ecomodder. Just understand they are hyper sensitive. I was perma banned after asking a few questions and positively commenting on some threads.
Colin Chapman disciple |
Problem, officer?
Drives: '06 Yaris 5DLB 1.5 Join Date: Oct 2010
Yikes! I have an account on ecomodder too, but fortunately I've never made a post.
![]() Regarding aerodynamics mods, I can't tell exactly how much mileage I did gain for each mod because they were all being put on gradually one by one. However, my best record after mod is 16.8 km/L (39.5 MPG); compared to 14.5 km/L (34.1 MPG) unmodded. 16% gain! [Highway driving, 100-120 km/h (62-75 MPH)] ![]() Underbody paneling. I glued 10mm-thick insulation foam sheets to the underside. I also attached corroplast panels ahead of rear suspensions. The car is now substantially quieter during highway drives. It also coasts/glides very well. (my butt-dyno says 20% increase in distance) ![]() Tail light vortex generators. I got this idea from newer Toyota models. The car seems a bit more stable at high speeds. ![]() I once installed (ghetto) roof vortex generators but ended up took them off, as they were too obvious. No effect on fuel economy, but stability on highway has been improved noticeably.
#4 | |
Perhaps also consider a scangauge, ultragauge or equivalent to monitor your fuel consumption. With my few mods I average about 40mpg city, according to the Torque app. Last edited by phaznet; 11-21-2014 at 09:16 AM. |
Thanks for the tips, are those vortex generators on the mirrors? Also I thought about raising the hood with spacers to deflect air over the whipers, any thoughts? I do currently have an ultragauge. I considered a crank damper but im unsure of the effects.
![]() Drives: 2010 Toyota Yaris Join Date: Nov 2014
Ive briefly checked the forum for the one ecomod I don't see. Fuel efficient tires. Are they a hoax? Do they work, I need tires for mine now i'm thinking of trying some. Just R and D you know.
Tires made for fuel economy generally just have a harder compound rubber to lower rolling resistance. the downside is traction...... in wet or snowy times they will slide easier. Not for me thanks. too many other areas effect mileage more to waste money on them. driving style, mechanical condition and pressure make up more fuel mileage more than tire compound.
Basically, dont waste your time or money on them. We have people in here using more sport compound tires getting 40 plus mpg. I'm using Hankook Optimo H727 because of treadwear and pricing and get 42 plus on the highway and get around fine in snow(up to about 4-5 inches) or rain. I used to keep them at 40 psi but have put them down to 35 cause I'm 60 yrs and getting to be a softy,lol. mpg went down by 1-2 when I did this, but I drive a work truck so my car only goes less than 50 miles a week now days. |
#8 | |
Thank You very much. I always had a hunch that the "fuel efficient" tires were like that. I will be looking at some General Altimax instead I believe, That was a great expaination Im glad I asked. |
I think better MPG is more of a factor of how you drive than how the car is modified...
I do too. It rarely sees anything over 60. I get 38mpg 50/50. 44 hwy.
#11 | |
And low rolling resistant tires should absolutely get better gas mileage. As was said, less friction means better gas mileage. Whether you think that is worth it for what they cost is another story. Tires can have a massive effect on fuel economy, my new tires were hitting 5mpg more than the worn tires I took off.
#12 | |
Enthusiast
Drives: 07 Yaris HB 1.3 (EU) Join Date: Nov 2014
Where did you buy the vortex generators from?
Sent from my HTC Explorer A310e or my awesome Xperia Z1 C6903 using Tapatalk.
Cheers, George. |
![]() ![]() Drives: '00 Echo Join Date: Mar 2014
LRR tires aren't worth the extra $$ up front, IMHO. Cheapies for me and I'll jack the pressure up to sidewall max, thanks.
Not much else in terms of mods which are worthwhile. You can build a belly pan for aero or a kammback, the latter doesn't appeal and the former is labour-intensive. Warm-air intakes decrease performance in exchange for a little FE boost. I do use a grille block in winter though, it's nice to maintain thermostat-open temps even when the ambient is under the freezing point.
I hadnt checked my tire pressure since I bought the car, it was 22 psi all around
I bumped it to 42psi all around so im hoping to see a difference.
I'll toss this in the mix: mods < driver in terms of fuel efficiency.
As to the list at the top of this page...aero mods are decently effective and full synthetics help. A freer flowing air filter/exhaust, not really, but if you can direct warmer, less sense air into the intake that can pay benefits. Full synthetics are a good mod as well. HHO lives in the land of the unicorns. Not very effective.
Spacers are here
| Yaris Fuel Pump | HTM Yaris | General Yaris / Vitz Discussion | 12 | 03-22-2012 03:34 AM |
| Change to high quality filter lead to drastic drop in fuel efficiency | lh59 | DIY / Maintenance / Service | 19 | 07-02-2009 02:22 PM |
